SOURCE: tecumseh 6.5 hp go cart wont stay running(carb?)
I had the same problem like 3 days ago
all I did was open the choke up all thie way get it to where it want close
then the screw that pushes the acclerator in to give it more gas when you start it
screw that in about 1cm or lil less
after that mess with that screw
you should get it
my starts first pull now and runs great and i had the same exact problem
SOURCE: Honda generator ei3000. Will run only a few mins
Tank filter not blocked? (Take tap off tank) Enough oil in motor? Try overfilling it slightly
SOURCE: 87 trail boss has spark and fuel but won't run
test the compression. it needs to be 90 psi or higher
SOURCE: in have a 1985 suzi gs550e it starts but only
I have an intermittent petcock problem with mine, check that. It has a vacuum switch in it that can stick
