SOURCE: I couldn't find Sansa on my computer when I connect with USB cable!
go into the Sansa m200 menu under Settings -> USB and select MSC instead of Auto Detect.
SOURCE: Unable to connect K550i to computer
uninstall the software then reinstall it....or change the usb cable
SOURCE: cannot connect LG U990 phone to the computer
Hi
I have finally tracked down the reason MY U990 would not connect (in data service )
It seems if you have more than 3 sub menus open it will NOT connect....
To fix this go to the ‘multitask’ icon in the top right hand corner of the screen.(the icon is a 3x3 grid with the top right hand square larger than the rest and coloured blue) I found by clicking on the items listed I was able to reduce the list to 2.
Hey presto connects just fine.
SOURCE: Cant connect to computer via USB connection. Software wont open or reads no phone connected.
You probably have the USB selection set incorrectly on the phone. Go to Menu, then Connectivity, then USB, then select "Data Service". The should fix it.
SOURCE: I can't transfer pictures from
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
