My Crown CTS Power Amp has a broken on off switch how do you open the case to get to the switch?
  • Audio Player... Master
  • 686 Answers
Hi Ed, I sent you the link to download the user manual of the CTS600 and CTS1200 Crown amplifiers
I hope ter serves to repair your Crown power unit
Greetings Franco Dosil
Hola Ed, te envio el link para que descargues el manual de usuario de los amplificadores Crown modelos CTS600 y CTS1200
Espero ter sirva para reparar tu unidad dee potencia Crown
Saludos Franco Dosil
https://data2.manualslib.com/pdf5/106/10592/1059159-crown/cts600.pdf?48095c310cea414e22394c5d55bb60d2&take=binary
https://www.crownaudio.com/en/product_families/cts-series
https://www.crownaudio.com/en/products/cts-600
Posted on Jun 16, 2019
2 Suggested Answers
SOURCE:
joecoolvette
  • 5660 Answers
SOURCE: open the asus ul50v case
No hints. Just a disassembly pictorial guide that is real close,
http://www.insidemylaptop.com/how-to-disassemble-asus-ux50v-laptop/
Okay, maybe a few...............(lol!)
1) Always remove ALL power remove the AC adapter (Charger), and Battery.
2) Use a multi-compartment container for the various screws you will remove. Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
As you can see viewing down the various photos in the pictorial guide, the Top Cover, along with the Display Assembly, is removed.
Has to be removed in order to access the Power Button Board.
In order to remove the Top Cover, the Keyboard is one of the items to remove first.
Look at Step 4.
The Keyboard Cable STAYS with the Keyboard. It removes from the motherboard connector.
Again,....Removes FROM the motherboard connector.
The Keyboard Cable is a FFC. Flat Flex Cable.
It has NO connector on the cable. The connector is on the motherboard, and stays on the motherboard.
The connector on the motherboard is made of two pieces.
It DOES NOT come completely apart!
If it is in two pieces it is broken, and you are looking at motherboard replacement.
Hence why I am being so detailed. Do not break it!
The motherboard connector has a larger bottom rectangular piece, which is the BODY.
It has a slimmer rectangular top piece, which is the Locking Bar.
The Locking Bar is wedge shaped. When locked into position in the Body, the wedge shape wedges the Flat Flex Cable, and locks it in.
The Locking Bar is Brown. All you will actually see are two tabs of it.
One tab on one side, and one tab on the other side.
Use your finger/thumbnails, and ease the tabs towards the cable itself.
(Away from the Body of the motherboard connector)
If you look close at Steps 4 and 5, you can see the brown tabs of the Locking Bar have been moved forward, and away from the Body.
The Locking Bar ONLY MOVES about 1 to 2 Millimeter's.
[2mm is a little larger than 1/16th of an Inch. 1mm is a little larger than 1/32nd of an Inch. Use a tape measure to compare, or another measuring device ]
I just searched to find a replacement Power Button Board. No luck on this end, hope you have better.
Regards,
joecoolvette
Posted on Jul 01, 2012
The power button is broken how to turn ontv
Hello Andrew
You didn't specify what you mean by "Broken"
Do you mean physically broken or
It just doesn't turn the tv on?
There are separate answers for each.
1:To fix a physically broken switch you could simply open the TV up and attach 2 wires to where the switch contacts are soldered to the PCB.
Run the wires to a new switch. Probably a NO (Normally Open) type. A Round switch could be mounted easily with a drill hole through an unused area of the case. Pressing a NO switch closes the contacts momentarily to trigger the digital turn On.
2:You could remove the old switch & attempt to get an actual replacement or a similar mountable switch from a components supplier.
3:If the switch is actually physically OK and the internal contacts are working (test with multimeter) then the problem is with the digital switch mode power supply that supplies power to the main circuits.
This would probably be caused by leaky Electrolytic Capacitors on the power supply PCB.
In that case, if your up to using a soldering iron and locating the Cap's then this would be an inexpensive way to fix the TV.
Good Luck
Switched mode power supply
Capacitor Replacement Tutorial
How to Replace an Electrolytic Capacitor
Apr 05, 2016 | Televison & Video
How do i change the fuse in my cts 600 amp
Try pressing the Reset Button, if that does not fix it take it to the repair shop. If you do not have experienc you can do a lot of damage.
Apr 27, 2014 | Amplifiers Crown Crown CTs 600 LITE CTs...
Crown CTS 600 manual
Here i have added the link to the Operation manual of Crown CTS 600 .
Crown CTS600 Manual
Ajin
Jul 12, 2012 | Crown CTS600 2-Channel Amplifier
CTS 4200 4 channel CROWN power amp I changed 2 output transistors on channel 1 they were both bad but I am still seeing a fault on channel 1. I tried changing the relay for that channel but the relay...
Try changing the emitter resistors near the parts you've replaced. Also when you change out transistors it's a good idea to change them ALL out..The "supposedly good" ones may be badly stressed.
If the output line to the spkr relay has more than a volt on it the amp will stay in Protect
Jun 24, 2011 | Crown CTS4200 4-Channel Amplifier
Input 60Hz hum
i had the same problem once and in my case i had accidentally used ground wire for signal. pls check ur connections again. one check u can do is set the high pass filter to 70Hz and see if that cuts out the low hum.
May 01, 2010 | Crown CTS600 2-Channel Amplifier
2003 CROWN VIC HAS NO SPARK AND NO POWER TO FUEL PUMP CHECKED RELAYS AND FUSES CHANGED CRANK AND CAM SESOR LOOKED FOR BAD GROUND AND BROKEN WIRES AND HELP PLEASE
DID YOU CHECK THE FUEL PUMP SHUTOFF SAFETY SWITCH ON THE LH/DRIVERS SIDE IN THE TRUNK & MAKE SURE IT IS DOWN ,& EVEN IF IT IS SOMETIMES YOU CAN TAKE SOMETHING & PUSH IT UP & THEN PUSH IT BACK DOWN & IT WILL CRANK,& BELOW THAT SWITCH IN THE TRUNK IS A FUEL PUMP DRIVER MODULE ,IT MAY BE BAD,THOSE ARE A COUPLE OF THINGS THAT HAVE WORKED FOR ME ,& THATS PRETTY MUCH ALL I DO IS WORK ON FORDS, & LX CROWN VICS & P71 POLICE CROWN VICS WHERE I AM WORKING, HOPE THAT IT MIGHT HELP YOU FIX IT. SEAN
Nov 02, 2009 | 2003 Ford Crown Victoria
Frigidaire Crown dryer will not start. Has power to it
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Jun 11, 2009 | Frigidaire Electric Dryer
Blinking red fault warning
timy check the speaker conections before condeming the amp
Apr 30, 2009 | Crown CTS600 2-Channel Amplifier
I pulled on the crown and it came off the stem
Do not open the watch yet, as you do not know how to get the stem out.
Take an eyeglass and examine the crown. You will find the small hub in the centre of the crown. If the centre of this hub is hollow and you can see the thread in it- you will be able to screw it back on stem (all watch crowns are screwed on to stems, never pressed).
If the centre of that hub looks filled with metal, then the stem end is broke and you will need replace stem AND crown (the metal filling the hub is the broken end of stem).
In case if the crown still in tact, let me know by asking questions and I'll guide you through all the process HOW TO.
Rate me, please.
Mar 24, 2009 | Watches
35 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
