No ring on lines on extension 11 and 12. How do I program to ring?
Please follow the steps given below
To set distinctive ringing
1. Press #9876 to enter User Programming Mode
2. Press a Line or extension button. The LED is steady green.
3. You can press Hold to switch between internal and
external pitch.
(Internal =
station calls within your system; external = outside line calls.)
4. Enter the two-digit pitch number (see table)
5. Press the same button that you pressed in
Step 2 (Line or extension). Two beeps is a confirmation tone and “DATA
PROGRAMMED” displays on your LCD.
Tone No. Frequency and Cadence
01
500 Hz 1 sec. On, 3 sec. Off,
repeat
02 300 Hz 1 sec. On, 1 sec. Off,
repeat
11 500/640 Hz 1 sec. On, 3 sec. Off,
repeat
12 500/640 Hz 1 sec. On, 1
sec. Off, repeat
13 860/1180 Hz 1 sec. On, 3
sec. Off, repeat
14 860/1180 Hz 1 sec. On, 1
sec. Off, repeat
15 1300/1780 Hz 1 sec. On, 3
sec. Off, repeat
16 1300/1780 Hz 1 sec. On, 1
sec. Off, repeat
17 860/1180 Hz 0.5 sec. On,
1300/1780 Hz 3 sec. Off, repeat
18 860/1180 Hz 0.5 sec. On,
1300/1780 Hz 1 sec. Off, repeat
Thanx
