SOURCE: Mac Book Pro forgetting Wi Fi settings
yep! Go to the Systems Preferences window and select NETWORK.. then select Airport and the advanced button... you can drag your networks to the order you prefer and then check the appropriate box at the bottom of the list to keep your log in ... that should do it!
SOURCE: My mac book pro is password locked by another user
In order to override/reset the root level password on your system you can boot up from a system disk (insert disk and restart holding down "C" key). If you don't have a system disk, there are other ways to do it: http://www.macosxhints.com/article.php?story=20080414140636495
Testimonial: "wow, this is great, can't wait to try it when I get home! "
SOURCE: Lost install disk for Mac book pro My 13" Mac book
You will need some install disks to even begin working on your issue.
Your options:
Once you have a install CD, I would recommend backing up your system by making a disk image of the hard drive to an external drive. Then doing a clean install and then using the Migration Assistant to restore your user files to the clean install on your hard drive.
