Check heating element
SOURCE: Thermostat or Heating Element?
Check out our element replacement guide at: http://www.ransomspares.co.uk/fan_element_article.html
SOURCE: Red light's on... but no hot water!
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
SOURCE: nissan pintara ti 91 u12
Your blend door in your car isn't functioning properly. The blend door is a part of the box that your heater core is in.
SOURCE: Front side heat element with ring wont light on ( or heat up)
These type of elements are often known as dual elements. They usually have two separate coils. More than likely the center coil has failed. They cannot be repaired and, in the case with your range, cannot be replaced separately. You will need to replace the entire element. Searspartsdirect.com carries parts for your range. Just type in your model number and locate item numbers 5301 and 5302 under the "Cooktop" heading. I do not know which front element your are talking about, but there is a price difference. No, thay aren't interchangeable. They have different wattage ratings. You will need to determine which one it is that you're having problems with. Replacing a single element is not difficult. It can be accomplished easily by following these instructions:
1. Unplug the range before servicing. Even with the unit turned off, there are potentially dangerous voltages present on the wiring harness.
2. Open the oven door and locate the two screws that hold the cooktop in place under the front edge. CAUTION: Do not put any weight on the oven door. You can cause damage to the door springs. Once you remove the screws to the cooktop, close the oven door.
3. With the screws removed, the cooktop will lift up.
4. Use something to prop up the cooktop, or a second person to assist, and carefully remove the mounting bracket to the two front elements. They are assembled together on the same bracket piece.
5. Gently lay the entire assembly on top of the oven box, leaving the cooktop propped up. Disconnect the wires to the affected element and unscrew the mounting clips. NOTE: There are numbered mounting holes on the element, pay attention to which numbers the clips are screwed into.
6. Remove old element. Install mounting clips to new element and reconnect wires. Install new element in mounting bracket and carefully lift back into place on the cooktop and install. NOTE: Use caution when handling the elements, they are extremely fragile. DO NOT touch the ceramic material, or electric coils with your bare hands. Oil transfer form your hands can cause potential hot spots, leading to premature failure of the element.
7. Lower cooktop and secure back in place.
The repair procedures are pretty straight forward. If you have any questions, please let me know. I hope this helps you.
SOURCE: I have an older model
THAT IS A FUSE you should be able yo get one from someone on line GOOGLE high temp fuse 185c and see what come up . we have them here , but we are a service center . so if i can get one so can you, somewhere .
