SOURCE: Dometic ac with atwood 1h2c thermostat will not come back on
Just a guess, as I am not familiar with the solar assist, if the stat is wall mounted I would remove it and verify if there is wither standard batteries, or a "watch" style battery. hope this helps
SOURCE: I need to find a cycling thermostat for a Dometic Roof top unit
I ran across the same problem and found the kit to expensive. I gutted the parts added a transformer, contactor and thermostat. Unit worked great and cost about half the price.
SOURCE: I have a 13500 btu ac dometic penguin model on pan
Your choices are another Dometic or a Coleman
I prefer the Coleman But the amount of extra cooling you will get by stepping up to a 15K unit will probability not be worth the added cost
SOURCE: Dometic duo therm ac unit replaced the thermostat
It sounds like it is wired wrong. Double check all the connections you made.
