SOURCE: magnavox 42mf230a smoked
It should be repairable, however I would suspect the cost to be about half what a new one would be. A circuit board plus labor can easily approach $500. If you're lucky and it was just a few easily replaced components like capacitors venting, then you could possibly get off with a few hundred less.
SOURCE: 95 Chevy Blazer 4.3 white smoke at idle
my 1988 chevy blazer 4x4 smokes on cold starts till it warms up then it goes away what is causing it
SOURCE: I own a brinkmann 810-3825-S and we are trying to
You will want the lid closed, the longer you can hold the heat/smoke in the better the flavor. What makes it smokey is wet wood chips on your coals, a smoker box works great for that but I think this model has it built in. You can get different wood types of wood chips at places where you can buy grills in the same department. You can usually get hickory, oak, cherry and such. Hope the ribs turn out good! :)
If you need further help, reach me via phone at https://www.6ya.com/expert/forrest_f5a3e9d21691ce99
