SOURCE: do Navman have a forthcoming
the update is projected to fix the problem but nobody really knows i would hang tight for a while although it can be frustrating and as of now the update should come out sometime next month.
SOURCE: Can't find my manual and need to reset the date and time
if system DK series must set at port "00"
#402 to check the port number with displayed phone
#651 DDMMYY - for date
#652 HHMMSS - for time
#653 to change the day
SOURCE: no change time
You will need to backup all of your tracks, waypoints and routes to your PC. With the unit off, hold down the page, enter (joystick), and find buttons for 5 to 7 seconds while power up at the same time. Then go outside and let the unit get a fix on the satellites. This will fix the date problem. Once done go to the main menu and select setup and the system. Make sure WAAS is disabled. If you enable this option the date will get messed up again and you will have to do this all over. There was supposed to be a firmware upgrade that fixed this problem, however I found after flashing the firmware update, the date problem still occurs if WAAS is enabled.span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
SOURCE: I have got a new
I own a Navman MY55T and I honestly don't think you have to reset date and time. I never have for mine.
I have had a look online for you for your model of Navman and could not find anything within the user manual except how to change the format display for day/month/yer or month/day/year.
My only thoughts Sync it with your computer and it may pick up your computers time and date like many other peripherals do when they sync to your computer. Or it may well automatically change when it picks up GPS info as you use it in your car.
Testimonial: "Your instant & prompt suggestion was very helpfull.I did try your way & it worked perfect..Many thanks"
