Jensen JHT525 System Logo
Posted on Aug 08, 2009
Someone replaced the subwoofer on a jensen jps12
Some one replaces my original jensen jps 12 subwoofer with a subwoofer with a much higher wattage, this has blown the onboard amp. is this amp fixable? or will a new amp need to be replaced
Jon Connors
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Apr 25, 2019
Jon Connors
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
6768
Points
17
It can probably be fixed but it might be cheaper & quicker to just replace the amp.
Here's a little tip for you for next time.
A lot of people say a sub can be "too big" for an amp & cause it to fry (burn out) but that just isn't the case.
You can put a 50 watt amp on a 1000 watt sub & it will play just fine for years to come.
A subwoofer does not pull power from an amplifier, the amplifier puts out what it's got & the sub can either handle it or not, it's as simple as that.
In the case of a higher wattage sub & a lower wattage amp, the sub will handle it just fine.
Now, where most people mess up is the ohmage of the subwoofer vs amp.
Different subwoofers & amps have different ohmages & those ohmages come in every size ever made, so the wattage of a sub or amp has no effect on the ohmage of the product.
In case you don't know what ohms are....
Ohmage is pretty much like back pressure.
Let's do a little example here,
Let's say you need to blow threw a tube & create a nice steady stream of air (kind of like an amp pushing power threw a sub).
How's it going to work if you try blowing threw a (lower ohmage) coffee straw?
At lower levels it will be easy, but as the level of air (wattage) goes up, the harder it becomes & eventually you end up straining trying to force air threw that straw (subwoofer).
Now same scenario but this time you are blowing threw a (higher ohmage) paper towel tube.
Now you end up trying to push so much air with such little resistance that you end up straining & winded trying to keep the pressure up in the bigger tube.
You need something in between. Something that offers enough resistance but not to much. That's what ohmage is between an amplifier & a subwoofer.
Hope this helps you have a better understanding.
Anonymous
Level 1:
  • Contributor 36 Answers
  • Posted on Aug 08, 2009
Anonymous
Contributor
Level 1:
Answers
36
Questions
0
Helped
12133
Points
99
NEEDED TO BE REPLACED
1helpful
My jbl 12 subwoofer has been making moise at high levels finally it quit, took it apart and fuse was blown. Should I replace the amp?
Well, you can replace the fuse and see if the amp works, but it sounds like the amp may have been over-driven. If you intend to drive the amp at higher levels than what the subwoofer is rated for, it will blow fuses, so you may want to consider a subwoofer that has a higher wattage rating.
Why wouldn't you connect the DVC Subwoofer in series, by connecting the other 2 connections Tom?
The impedance tends to be unmatched. It would make the impedance higher and the amplifier will give out a different output wattage.
Wiring diagram for jp12 subwoofer
your sub woofer has only one input to make it work. plug in your rca cables into the back of the sub woofer and the other end into the audio out or subwoofer out put on the back of your surround system.
also has 2 speaker inputs so you can expand your speaker setup. plug thos in and you can hook up 2 speakers to th output on the back of the sub.
Is my 1200 pioneer amp a good match for my 1200 watt pioneer sub
this is too close, your speaker wattage is alway's higher than your amplifier's wattage alway's to be safe because the hard pounding will make the speaker work harder, and this will cause your speaker burn out easily, though you can adjust your amplifier anyway's
Putting Subs in a Ford Five Hundred witout replacing stereo syst
yes you can buy higher wattage subs depending on what watt the amp is
1helpful
Jensen JPS12 growls at random...
Get rid of it and get a real sub!
JS 1000
audiovox ownes jensen so you might try this site, but no js 1000 models are shown, however, jps 8"/10"/12" are and you can download pdf manuals. one may be comparable to yours. or you can contact their customer service and they may be able to help further.
http://www.audiovox.com/webapp/wcs/stores/servlet/GenProductListCmd?categoryId=5025&type=prev&langId=-1&storeId=10001&catalogId=10001
sorry not a better solution.
3helpful
2answers
Farting Noise
Do a more detailed search there is a solution but you will have to send it out to get repaired the noise is from when it goes on stand by...jensen is of no help
2answers
Jensen Subwoofer JPS-10
This sound is made by the automatic shutdown in the speaker. Jensen repaired my unit under warrantee.
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Ngoro
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
