Question about Boating
Is there a way to reset guardian mode on a 2002 150 optimax? I am currently offshore and about to go through one of the roughest inlets
  • 1,116 Answers
I don't think you can reset it. Whatever the problem is, that needs to be corrected otherwise it will just go back into guardian mode. On a mercruiser forum, people posted that once the specific problem was corrected, the unit turned off guardian mode automatically.
Posted on Jun 15, 2019
2 Suggested Answers
SOURCE:
  • 18067 Answers
SOURCE: 2011 Mercury optimax. At 3500rpm alarm goes off and goes in guardian mode. Water pump and pressure good. Oil level is good. Oil pump working correctly. Changed internal pressure regulator. Any advice?
This could be a lot of things. Have a computer scan done to see what the issue is. Could be a bad poppet or water pump. There is a sensor in the oil tank that can cause this too. Also the throttle sensor.
Posted on Apr 27, 2018
Testimonial: "Thanks for the info, I'll try these suggestions tomorrow!"
Instruction manual for phone guardian 100
The quick start guide for the Phone Guardian 100 Wireless Emergency Alarm is available on the product page: http://www.m2cshop.com/store/Phone-Guardian-100-Wireless-Emergency-Alarm-Telephone-NEW-Free-Delivery-p-169.html . The direct link for this guide is currently http://www.m2cshop.com/store/Downloads/pg100.pdf .
I hope this helps.
Jun 19, 2018 | Cell Phones
Apr 27, 2018 | Mercury Cars & Trucks
Can a demo unit of the Uniden Guardian system be used?
http://www.manualslib.com/manual/388611/Uniden-G455.html
Jun 24, 2014 | Uniden G455 Guardian Wireless Video...
Mercury optimax problems
I would reccomend contacting the dealer .
Jun 10, 2014 | Boating
Over current light
its unlikely its the battery. it will be more like it is running too fast for some reason. i would contact generac for advice. or join the forums at ziller electric .com
Dec 28, 2017 | Electrical Supplies
Replace phi 212 ga cell for guardian air
You can find replacement cells for the Guardian Air RGF products here:
http://hvac-parts-online.com/indoor-air-quality-replacement-uv-bulbs-c-82263_82296
You will have to call for current pricing. The manufacturer has asked us to remove pricing from the internet. 941-735-7151
Sep 24, 2011 | VisionAir Vision Air PHI Guardian Air...
How do you make it blow air out? trying to make air blow out,i have the hose that has controls on it. will work to **** up but when i put it to blow out will not come on.
The Guardian Canister vacuums have a blow port under the filter. So you need to remove the filter (on the Guardian Ultra, you have to open the top of the vacuum) by lifting it up the forward. Then disconnect the hose from the normal suction end of the unit and plug it into the blower port. Now turn on the vacuum. If the hose is clogged, position the other end of the hose at the suction port.
For the Guardian canister, select the high, medium or low force for the motor. Then blow the dust out from under the furniture or use to fill an inflatable. Turn off the vacuum and replace the hose in the usual position and replace the filter when done.
If you are still unable to get the unit to blow out when connected to the exhaust port after attempting to clear the hose, separate the hose, wand and handle. Look down the hose for any object that might be creating a one-way valve. Remove the foreign object.Do the same with the other parts of the unit. Also replace the vacuum bag. If the bag is sufficiently full, the airflow will be reduced through the bag to the exhaust and cause the problem you describe.
The Electrolux Guardian Canister Vacuums are part of the Aerus line. The manuals for the vacuums are available here: http://www.aerusvacuums.com/support/manuals/index.cfm . The Guardian Ultra is in the current model section. The Guardian is listed in the Older Model drop-down menu.
I hope this helps.
(many canister vacuums have a blower mode when you connect the hose to the exhaust (after the bag) instead of the suction side of the unit.)
Aug 17, 2011 | Electrolux Guardian Bagged Canister Vacuum
Need replacement phi cell for guardian air. zip code 45365
You can obtain replacement cells for the Guardian Air RGF products here:
You will need to call us for current pricing. The manufacturer has asked us to remove pricing from the internet. 941-735-7151
Feb 09, 2011 | VisionAir Vision Air PHI Guardian Air...
Have a 16k propane guardian generator have to manually start and
Is this an RV generator?
If you have to really choke an LP engine but it runs more or less normally once started you need to troubleshoot the demand regulator and the fuel supply lines (look for air leaks). I'd also check the fuel inlet pressure before the demand regulator.
Rate me,
Carl
Nov 19, 2008 | Guardian Rv Generator 4800 Watt, Gasoline,...
Boating Logo
Top Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
