What kind of tablet? how long has it been since it was charged , how old is it ? these are all things that should have been addressed in your question for us to be able to help you properly
Not sure why your removing the battery? If you are shuting down the machine. Close all running programs before shuting down otherwise the machine has to close each program in turn before thr machine can shut down all together. Depending on how the settings are for the power button. The shut down process can be forced by holding down the power button until the machine has shut down. Black screen instead of white. Hope this helps answer your question. Regards Bob from OZ
I'm having the same kinda problem but it's random or sometimes it duzent Finnish booting I know it's not over heating iv COMPLEATLY taken it apart and cleaned everything and applied new artic silver paste... and the ram is fine.. I have tested it in a nuther laptop.... It duz this on both battery and ac power.. Any clue what it could be?
Sounds like your android is frozen. try *holding down* on the power button, to see if you can get it to shut down that way.
If you're using a phone or tablet with a battery that can be accessed- try also taking the battery cover off , unplugging the battery, re-seating it, then turning the unit back on to test. (Warning: some tablets and phones do not have user-changeable batteries!)
Denon receiver has a common problem, keep shuting down after power button press, then red light blind. mostly, if none of amplifier output transistors blown, it must be IC7815 or IC7915 mulfunction, find it, replace it. then job down
You should have an error code legend in your owner's manual. Check to see what "OE" relates to on the washer. If not in your manual, you should be able to determine what the code relates to via LG's website. You may need to contact an appliance service company.
This could be caused by MANY different things. If it is a random thing, where do you have your laptop when it happens? If it isn't on a flat smooth surface, it's probably a heat related issue. Laptops need a lot of air circulaton, through the bottom.
