Http://www.fixya.com/support/t8868974-kettler_treadmill_tx_3_gives
Question about Kettler TX3 Folding Treadmill
Kettler Treadmill TX 3 gives error 91 supplier told it was the Power supply print. We changed it including the motor and the problem was solved for a couple of weeks. Now it is back again? Please give a good explanation of the error 91 and the solution of course. Thanks in advance, Remco Kapteijn
Posted by 0335_che on Apr 05, 2011
Problem with Trendmil TX-3 err-91 problem is solved ... speed sensor (photo transistro in photo cell is damaged).The palsis in colector is 5V Amplitud .
https://translate.google.com/#view=home&op=translate&sl=auto&tl=fr&text=Kettler%20Treadmill%20TX%203%20gives%20error%2091%20supplier%20told%20it%20was%20the%20Power%20supply%20print.%20We%20changed%20it%20including%20the%20motor%20and%20the%20problem%20was%20solved%20for%20a%20couple%20of%20weeks.%20Now%20it%20is%20back%20again%3F%20Please%20give%20a%20good%20explanation%20of%20the%20error%2091%20and%20the%20solution%20of%20course.%20Thanks%20in%20advance%2C%20Remco%20Kapteijn%0A%0A%0APosted%20by%200335_che%20on%20Apr%2005%2C%202011%0A%0A%0AProblem%20with%20Trendmil%20TX-3%20err-91%20problem%20is%20solved%20...%20speed%20sensor%20(photo%20transistro%20in%20photo%20cell%20is%20damaged).The%20palsis%20in%20colector%20is%205V%20Amplitud%20.
Le tapis de course Kettler TX 3 donne une erreur 91 Le fournisseur a dit qu'il s'agissait de l'impression du bloc d'alimentation. Nous l'avons chang?, y compris le moteur, et le probl?me a ?t? r?solu pendant quelques semaines. Maintenant c'est de retour? S'il vous pla?t donner une bonne explication de l'erreur 91 et la solution bien s?r. Merci d'avance, Remco Kapteijn
Publi? par 0335_che le 05 avr. 2011
Le probl?me avec Trendmil TX-3 err-91 est r?solu ... capteur de vitesse (la photo de la photo dans la cellule est endommag?e).
SOURCE: PRO FAX SAMSAUNG SF 2800
jai un fax/tel samsung sf2800 je n'arrive pas a le regle en de tel façon qu'il sonne 3 fois puis il se converti automatiquement en fax,car c'est ecris en allemand.
salutation amicale.
SOURCE: j'ai un dell xps m1530 service tag HM3BC3J mon
administrtor password HM3BC3J-595B
TRY = 8orsev43
SOURCE: Bonjour mes chers. Mon copieur
Verifie pour ton unite de fixation pour ta temperature ou tes thermistances si elles sont bien en contact avec le rouleau de fusion
SOURCE: Je possède un copieur Ricoh
SC 546: Unstable fusing temperature
Symptom: The fusing temperature does not rise
3 °C or more within 5 seconds after the
fusing lamp has been on over 8
seconds.
Possible Cause: • Thermistor defective
• Power supply unit defective
SOURCE: BONJOUR JE POSSEDE UNE IMPRIMANTE
Bonjour cevale358 ,
Il n' y a malheureusement pas d' autre solution que de rentrer l' imprimante chez Samsung pour r?paration . Il s' agirait malheureusement d' une panne assez courante sur ce mod?le qui concerne le fusible et l' unit? d' alimantation .. Voici quelques pr?cisions si tu comprends l' anglais ... http://www.fixyourownprinter.com/forums/printer/66821
Cordialement ,
fanaudi .
