Question about Radio Communications
Model FOS48TA-BL I can not get it to pair. I do not have a setup icon just a pairing icom.
SOURCE:
SOURCE: can h700 pair w/multiple devices?
Jabra JX-10 II but i'm not recommend because my friends said that this model not as good as normal JX-10( low volume, low signal, more noise, sth like that)
Posted on Jan 08, 2008
SOURCE: BL-PA100 HD-PLC not pairing up,
Try using another cable.
Posted on Jul 24, 2008
Just_Bobz
  • 448 Answers
SOURCE: need code to pair my technocel bluetooth
If you haven't found it yet, use 0000. If this is helpful, please post as such. If it fixed it please post as fixya
Posted on Jan 15, 2009
  • 3230 Answers
SOURCE: I'm trying to pair my A7010 with a Phonak icom.
What is the model number of icom, it seems that icom not support it.
Post comments for more info.
Thanks
Posted on Jul 14, 2009
dancandoit
  • 436 Answers
SOURCE: cant pair parrot to nokia 5800
you will have to pair them together again, search for devices from your phone and select parrot, then enter pin code 1234 when prompted, this should then pair again.
Posted on Nov 15, 2009
How do i use my blue tooth tablet to connct to my hearing aid via phonak i-com?
you need to go into the tablet settings and find the bluetooth settings most likely under network. then you need to add a bluetooth device.
at the same time you need to put the icom into pairing mode see
http://www.phonak.com/content/dam/phonak/b2b/C_M_tools/Accessories/iCom/Documents/com_icom_pairing_guide_others-xx.pdf
also see
http://www.phonetipsandtricks.com/tips/asus-transformer-pad-infinity-tablet/pair-with-bluetooth-speakers-or-headset-46/
if you need a code it will most likely be 0000
Nov 16, 2014 | Phonak ComPilot
Bluetooth pairing code
Cantz bluetooth speaker sometimes pairs with tower and as often not.
Jan 04, 2014 | Ergoguys HS-BTV60S-BL Hip Street yak...
Can not get it paired to iphone 4
Goto Preferences (the gray gear icon - should be on your home screen
Then Bluetooth
Turn your headset on (on my phone this is done by flipping down the plastic tab that touches your upper cheek
The iphone screen should then see it and ask for a pairing
If it doesn't, one by one press any other adjacent icons until you see the request to enter the Pairing passcode
If you don't know the pairing passcode, most headsets use 0000, but if that doesn't work you will have to enter into a Google search
"(Your headset brand and model) Bluetooth Passcode"
and search the resulting links until you find it
Oct 08, 2013 | Jabra Bluetooth Headset with Adjustable...
Need manual for wiring phones
The 612 system required 3 pairs per phone. Every 3 pairs on the 25 pair cable would be one station. A modern 6 conductor jack would be wired according to the label. If you have jacks with Green,Red,Black,Yellow,White, and Blue wires, then it's wired as follows.
W/Bl - Green
Bl/W - Red
W/Or - Black
Or/W - Yellow
W/Gr - White
Gr/W - Blue
Oct 12, 2012 | Inter-Tel (660.7600) Corded Phone
Installing mad catz ps3 bluetooth
In order to use it you have to pair it with the PS3.
Pairing is a process of associating Bluetooth devices with each other. It will establish a permanent security link between the devices and enable quick access to the services provided without the need to re-enter Pass Keys. You will only need to pair your PS3 and the Headset once.
Paired devices remain paired even when:
-One of the devices is powered off.
-A service connection is interrupted or stopped.
-One or both devices are restarted.
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be 'paired' so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
1. Power on your PS3 console.
2. Within the "Settings" menu, press X on "Accessory Settings."
3. Press X on the icon labeled: "Manage Bluetooth® Devices."
4. Scroll down and press X on the icon labeled: "Register New Device."
IMPORTANT: Depending on your model of the 8860 Bluetooth® Headset, your power button is either an oval shape with an icon of a circle with a line going through it (5a) or it is a button with a phone icon (5b). Please follow the appropriate next step depending on your model of the 8860.
5a. Once at the next screen, prepare the Headset to be paired with the PS3 by holding down the K1 button until the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the Headset to be paired with the PS3 by tapping the pairing button located next to the volume controls on the side until the LED flashes BOTH Blue and Red.
6. Once the Headset's LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on "Start Scanning."
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices within range.
8. Locate "8860" from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: "Register completed"
Trouble Shooting
Q. The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Q. The Headset cannot be activated after being charged for 20 minutes.
A. To activate the Headset, the battery needs to charge for at least 40 minutes. It is highly recommended to fully charge the battery before use.
Q. No indication of charging is shown.
A. If the Headset battery is empty or has not been used for a long time, it may take some time for the Headset LED indicator to show charging status with a steady Red light. Make sure the PLAYSTATION 3 is turned on. The 8860 cannot charge without the console being turned on.
Q. No sound can be heard from the Headset.
A. Please make sure of the following:
-Make sure that the two devices have been paired.
-Make sure that the Headset is turned on.
-Make sure that the two paired devices are within 30 Ft. (9.15 meters) of each other.
*** Do not try to pair the headset to the PLAYSTATION 3 when the headset is attached to the USB cable. If it is attached to the USB cable when trying to pair up, it won't pair with the PLAYSTATION 3. ***
Feb 27, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
I cant find instructions to sync my Mad Catz PS3 Blu tooth headset
Hope it helps:
Trouble Shooting
Jan 30, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
How do you get the ps3 to pick up the blue tooth head set
Before the Headset can be used with the PS3, the two devices must be ‘paired’ so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
2. Within the “Settings” menu, press X on “Accessory Settings.”
3. Press X on the icon labeled: “Manage Bluetooth® Devices.”
4. Scroll down and press X on the icon labeled: “Register New Device.”
6. Once the Headset’s LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on “Start Scanning.”
8. Locate “8860” from the list of available devices and press X on its icon to be prompted for a Pass Key
10. You should then be taken to a new screen stating: “Register completed”
Trouble Shooting
Source: www.madcatz.com/faq
Aug 11, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
Installed a lexmark pro200 printer to windows 7, wifi now the computer is asking for a pairing code, what is a pairing code, and where do
No need to contact technical support for this. I just figured this out. Press the button with the wrench icon underneath the power button. This will take you to a setup menu for wireless access. Push the button "ok" for push button access and a Pairing Code with appear on the LED screen. Enter this code into the field of your add printer/device setup field in Windows7. Press ok and the Lexmark will be setup. I never saw this as an answer on any webpage.
Jul 11, 2010 | Lexmark Prospect Pro205 Wireless...
I'm trying to pair my A7010 with a Phonak icom. I can't hear a dialtone
Thanks
Jul 14, 2009 | Jabra A7010 Bluetooth Headset
My lg incite bluetooth does not detect the motorola S9 bluetooth
this took me nearly an hour to figure out, but here goes:
go to "settings icon" - tap "bluetooth" - turn it on - go to "accessibility" tab - make sure your phone has a "name" - then make sure "allow other devices to connect", "all devices" and "other devices can discover me" are selected - then go back to the "general" tab - tap on the "bluetooth manager" link - go to "active connections tab" - click on "menu" at the bottom right corner - click on "paired devices" when the menu comes up - click on "add".
Now quickly put your bluetooth headset into pairing mode and as soon as the device and passkey asking screen comes up, tap on the little windows "find" (or "search") icon next to the "device" field. once your phone detects your headset, it will take you back the device and passkey screen, where the name of your headset will now appear in the device field. all you have to do is input your device passkey.
Now go back to "bluetooth manager" screen, where in your "my shortcuts" tab, your "hands-free connection" icon should be present. if it's not, then click on "new" in the bottom left corner and select the "hands-free/headset setup". On the screen that comes up, select "next" which will take you to the next screen. Here your headset device icon will be present with a small red checkmark beside it. Tap this and your phone will establish a connection with your headset. It will then take you back to "bluetooth manager" - "my shortcuts" screen where your "hands-free connection" icon will now be green with two small arrows beside it pointing towards each other. If you click on the active connections tab, you'll see your headset device icon there. Also, a pair of headphones will pop up on your windows toolbar at the very top.
After this setup, to ensure your phone's security, go back to the "settings" - "bluetooth" - "accessibility" tab. Select "paired devices only" under the Accessibility heading, and deselect "other devices can discover me".
Hope this helps everyone...so far this is the only non-user friendly feature of the phone that I've come across, rest is pretty good and highly customizable.
Mar 20, 2009 | LG Incite Cell Phone
Radio Communications Logo
23 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
