NO PC STATED, JUST 30 YEARS OF HP COMPUTER.
BUT is 2007 or never with w10, is it 32bit or 64bit PC and OS?
type winver in the run box to learn what you run.
or is windows dead, (unstated also)
my guess wild , is you forgot to type this.
Error Code 0xc0000001 in Windows
we first run HDD tests, after all if the OS is corrupted (per above)
then repair or fresh installs will fail on all bad or weak HDD.
so if that passes read this
https://answers.microsoft.com/en-us/windows/forum/windows8_1-update/unable-to-boot-error-code-0xc0000001-youll-need-to/520d5a3f-1fbb-4a9a-98d1-03a8201f00ed
SOURCE: Getting code 10 error
Uninstall and then reinstall the software from the CD - this is the fix suggested by both the manufacturer and Microsoft for Code 10 errors.
-Tha Mp3 Doctor
SOURCE: Samsung YP-U3 not recognised. This device cannot start. (Code 10)
SOURCE: driver ricoh webcam HP pavilion DV6000
I had the same problem of code 10. I am using an HP pavilion dv6000 with a ricoh webcam. I found that I download a microsoft updates on the 8th of febuary which included some sonix drivers which were optional and no good to me but stoped my webcam working.
By going into 'control panal' and selecting 'system' then 'devise manager' you get a list of your system. If you then select the 'universal serial bus controlers' at the bottom you will see the sonix driver. By rolling back this installed driver I found my webcam started working again.
This solved my problem and I cant believe there aren't a lot of people out there with the same problem. Good old microsoft!
SOURCE: an mtp device cannot start due error code 10 whats that
I solved the code 10 problem on my vista 64 by using Revo uninstaller on the next to highest level to remove Acronis 10.4942 After this all media readers appeared and worked. A later version of Acronis Emergency boot disk still works to backup/ restore my system
SOURCE: optiarc dvd rw ad-7561a ata device
had the same issue and was able to resolve it by going to HP Compaq's websibe (for you it would be eMachine) and they provided the following information & i uninstalled the driver in device manager after running the below fix, scan the system for new hardware and the DVD drive appeared with the correct driver. hope this helps. good luck.
To resolve this issue, remove upper and lower limits from the registry. Upper and lower limits are points of your computer's registry that control the drivers for your specific device—in this case, the optical drive.
Remove upper and lower limits from the registry using the Microsoft Fix this problem link below:
If Microsoft's automatic fix does not resolve the issue, try using the other methods listed in this document to troubleshoot the issue.
