Hi there, if you're talking about the Buzz Lightyear Ultimate Talking Room Guard, to turn on the room guard, press his voice simulators twice. After he talks, press it again, then after 30 seconds he will be in room guard mode. Press his voice simulators and he will tell you that you entered the wrong code, press them five times and he will turn off the guard.
SOURCE: how to wire a cooper industries 6107 3-way motion detector switch
I opened the box and traced the lines to see which are connected
when the switch is turned on and I left the red wire disconnected.
SOURCE: how do i remove wing pack on buzz lightyear
Pop the wings out, put your fingers under the bottom edge of the jet pack and pull hard. The Jet pack comes right off and the wings stay attached to the toy. This gives you access to the battery compartment.
SOURCE: I lost the instructions for
batteries are located on the back of the legs under knees 4 AA each side and 3 AAA batts on top of the switch on the jet pack
i hope this will help you and that you let everyone here know this solved your problem.
SOURCE: need replacement helmet for original
Call the company which is on the back of the toy and all the serial/1-800 number. Ask for a replacement helmet and they should give you one for a small fee. Good luck! If it's an older toy sometimes the company no longer carries a part, and you can find a new/used model of the toy and have spare parts as well..on ebay.? Good luck!
