SOURCE: SD card for Vivitar ViviCam 4000
hi there
i'm afraid the biggest card you can use on this camera is 512 mb, which should give you about 150 pics at medium quality.
if this was helpful please leave feedback
beergut707
SOURCE: Vivitar ViviCam X014 will not turn on. Memory
Buy a real camera. X014 is cheap and has a foggy cheap lens. It will never take a good quality picture. It is a waste of a 10 megapixel chip!
SOURCE: I just bought a Vivitar ViviCam T027 camera. The
Hi there
Funny, I recently bought the exact same model. The answer to your question is simple (that's the good news!)
A long time ago, when these small SD Cards first appeared, they were limited in capacity from 128 Megabytes (MB) to a maximum capacity of 2 Gigabytes (GB).
To enable the same size card to store a greater capacity, a new specification had to be created. This new spec. was SDHC, and allowed the cards to store from 4 GB up to 32 GB.
The confusion arises because people still refer to all these cards as 'SD cards' when the higher capacity cards should really be called 'SDHC' cards.
Your camera will accept standard SDHC cards. Just make sure you don't order 'mini' cards which are much smaller in dimension.
Hope this clears up the confusion.
Phill R
Testimonial: "You explained it perfectly. Your right, Vivitar caused the confusion by referring to an SD card rather than an SDHC card. Thanks for your help."
SOURCE: i purchased a vivitar vivicam
Buy a SD card at Big Lots.I think they are $12 or $14 for a 4gb and i would think it would fit if it takes a standard size SD.
SOURCE: why does my Vivitar vivicam x018 keep saying "card
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If this doesn't do it, try another card.
Start getting paid every month online from home more than $15k just by doing very simple and easy job from home. Last month i have earned $17954 from this online job just by giving this 2 hrs a day using my laptop. I am now a good online earner. Get this job you guys also and start earning money online right now by follow details here............ ===>>>www.payshd.com
