Hello Gerardo, check the impedance of your speakers are 8 Ohms or more, if they are less than 8 Ohms, you can produce the failure you say
It also checks the real power that each speaker can handle and that is according to the manufacturer's specifications
Check the connections of the speaker cables, which do not have copper hairs that are joining between the positive and the negative
Test, disconnect all the speakers and go connecting one to one and try in high volume, then disconnect that and connect another and tests, so with all
This test is to know if you have any speaker with problems
If you can not solve, look for a specialized technical service
Greetings Franco Dosil
Hola Gerardo, comprueba la Impedancia de tus bafles sean de 8 Ohms o mas, si son de menos de 8 Ohms, puede producirte la falla que comentas
Tambien revisa la potencia real que puede manejar cada parlante y que este de acuerdo a las especificaciones del fabricante
Revisa las conexiones de los cables de parlantes, que no tengan pelos de cobre que se esten uniendo entre el positivo y el negativo
Prueba, desconectar todos los parlantes e ir conectando de a uno y probar en volumen alto, luego desconectas ese y conectas otro y pruebas, asi con todos
Esta prueba es para saber si tienes algun parlante con problemas
Si no logras resolver, busca un servicio tecnico especializado
Saludos Franco Dosil
https://usa.yamaha.com/files/download/other_assets/1/334221/RX-V995.pdf
https://www.manualslib.com/manual/197447/Yamaha-Rx-V995.html
SOURCE: Yamaha AV Receiver RX V-995
You may have a problem in the primary stage in your Power supply !! Unhook everything that is attached to it .... make sure the power plug is in good shape and you have the right amout of ac at the plug and good grounding ... then then try turning it on again ....
Does it stay on ??
if not .. there is something wrong probably in the primary stage of the Power Supply ... could be a bridge or something like that
hope this helps
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag. press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
SOURCE: Yamaha rx-v995
I'm in the same boat w/ my v995 - it has a bad volume motor and its $150 for the part. You want to sell your v995? Adam
SOURCE: Yamaha RX-V995 -volume knob sticks in one spot when using remote
I'm willing to sell my v995...just make me an offer and pay for the shipping and that baby is yours!
SOURCE: Yamaha RX-V550 AV Receiver Stuck on Zone 2
You can always do a system reset. there should be instructions in the handbook
