To cancel the red flashing light on the NEC DT400 associated with the reception extension key, follow these steps:
Hold the Exit Key: Press and hold the Exit key.
Select MW (Message Waiting): While holding the Exit key, select the MW (Message Waiting) option.
Choose "All": From the available options, choose "All".
This should help resolve the issue related to the reception extension key. If you encounter any further difficulties, consider referring to the NEC DT400 User Manual or contacting your NEC Authorized Supplier for additional assistance.
SOURCE: Flashing red status light on NEC VT45 projector
make sure the doors are shut all the way! there is a little button there.
SOURCE: NEC PX-42VM3A 42" Power problem
Yes the clicking noise does confirm a power supply related issue. The clicking noise is caused by the relay switches turning themselves of due to over load of certain circuits or it was not reset after a previous power surge. Rest the tv by unplugging the set from power supply, hold for 2 minutes and plug it back in. See if the problem persists and let me know.
Sai.
