I think no any issue create because all function is same and i also used hotmail to outlook email used and also new version available. Or no change ID or password, just change look or services, but function is same. If you have problem link not open email not sent mail, account related issue, setting issue, or browsing issue just go to outlook help and search you own problem, there step by step problem solved or contact hotmail technician.
Check your Junk folder
1. Sign in to Outlook.com account.
2. Click on
Junk on the left pane.
3. Check to see if the missing mail is in this folder.
4. If you see any messages that should have been delivered to the Inbox, click the
Not Junk.
Check your Blocked sender list
1. From your Inbox, click the cog icon.
2. Select
More Mail Options .
3. Under "Preventing junk email", click
Safe and blocked senders.
4. Click
Blocked senders.
5. In the Blocked senders list, select the name or domain (the part of an e-mail address that follows the @ sign, such as outlook.com) that you want to receive emails from.
6. Click
<< Remove from list.
Add the email address to your Safe senders list
1. From your Inbox, click the cog icon .
2. Select
More Mail Options .
4. Click
Safe Senders.
5. In the text box, type in the email address or domain you'd like to always receive emails from.
6. Click
Add to list >>.
Check your Email Rules
2. Select
More Mail Options .
3. Click
Rules for sorting new messages under "Customizing Outlook".
2. Perform one of the actions as per your requirement:
Click
Edit next to the rule that you want to edit.
Or
Choose the rule that you want to delete and click
Delete.
Note: Not all international characters are supported as filters.
Check your Junk Mail Settings
2. Select
More Mail Options.
Filters and reporting.
3. Under "Choose a junk e-mail filter", choose the level of protection that you want, and then click
Save. If the Exclusive level was set, all emails will go directly to your Junk folder except for messages from your contacts and email addresses that are in your safe senders, Outlook service announcements, and alerts that you signed for.
4. Click
Save.
To go back to your inbox, click
Outlook on the top left portion of the screen.
Check your Reply-to address
2. Select
More Mail Options .
3. Under "Writing email", click
Reply-to address.
2. Select the radion button beside
Current e-mail address.
3. Click
Save.
Thanks
Hotmail Support
-contact your email provider, typically your ISP.
-have a friend send an email and see if it bounces back.
-check your Junkmail/Spam box
