Question about Electrical Supplies
Generator RPM is going up and down its not stable
    New Friend:
Sounds like the Carburetor isn't sending the Gas fast enough, I would put Real Gas/ Marine has they call it. Then clean the Carburetor..
Posted on Jun 13, 2019
3 Suggested Answers
SOURCE:
  • 53745 Answers
SOURCE: I have a perkins generator 120kw when it reaches 80kw the rpm dropes but at 50kw its stable what could be the problem ?
could be a problem with the condition of the motor ( do a compression check )
could be a governor problem in the fuel pump or possible a fuel delivery problem
check for a black slime in the fuel tank and if found clean out the entire fuel system, filters lines and with the new fuel use a diesel conditioner . if the fuel is clean then the problem will be in the fuel pump not giving full fuel to the injectors under load
if the engine rpms are electronically controlled ( throttle lever to electronic control) check that movement of the lever or the control unit
Posted on Jan 22, 2016
  • 53745 Answers
SOURCE: RPM Caterpillar generator not stable. Any solutions ? Thanks
problem with the governor controls
if electronic controlled governor it could be the electronic system is faulty
If manual control , check for governor lever operation
check for fuel flow problems , blocked filters , low fuel level vent ing for the fuel tank blocked
Posted on May 28, 2016
Keep getting under voltage fault. I have cleared fault several time. generator will run for short period then fail.sometimes the fault is underspeed.
See if reducing the number of things connected to the generator will stop your problem. Disconnect or turn off some things that are not totally necessary.
To properly generate electricity, the engine is required to maintain an rpm within a specific range. If you load down the generator with too many things pulling power, the engine will not have enough HP to turn the generator within the set rpm range. It goes under-speed or under-voltage and you get a fault.
Going to the extreme, if you disconnect everything from the generator and it still fails, you have a generator problem
Sep 19, 2017 | Electrical Supplies
May 28, 2016 | Caterpillar Electrical Supplies
Coleman vertex 7500
The capcitor needs checking in the end of the alternator
Oct 03, 2013 | Electrical Supplies
High idle
most cheaper generators do not have a idle kick down and are made to run at 1850 rpm's the older ones run at 3600 rpm if it has a no load idle system there will be a switch
Aug 27, 2012 | Craftsman 5600 watt Generator
The coleman voltage generator for 250 kva gen set
Well I assume that this generator is NOT three Phase, and delivering 440 Volts? in that case, that reading is what is called and "Open Circuit" reading, with a full load, that reading will/should come down to the nominal voltage of 250 V (+/- 10%) This generator is a 250 V AC unit? If this is so then it is operating correctly? It is 5kw UNIT. using a digital multimeter due to it's large input impedance it will often give erroneous readings if NOT loaded down with the correct.any. load.?
Mar 02, 2010 | Coleman Powermate Powermate 5000W...
RPM/voltage fluctuation on Guardian Primepact 50G
go to www.zabatt.com - look in their Service manuals section - good luck!!
May 28, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
Suzuki Baleno (esteem) 1999. Engine Idle RPM not stable
you probably need to check the butterfly. its the compinent that controls how much air goes into the engine if it is weared than in idle state air leaks into the engine sometime more sometimes less and cause fluctuations in rpm
secondly there is a rpm switch which controls the rpm you can replace that switch and check
May 18, 2009 | 1999 Suzuki Esteem
How can i play videos in fedora10
This is what the VLC website says:
Fedora 9 and Fedora 10 Use RPM Fusion for F9 and F10 (available for x86, x86_64, ppc and ppc64)
Install rpmfusion-free-release-stable.noarch.rpm for F9 and f10
$> su -
#> rpm -ivh http://download1.rpmfusion.org/free/fedora/rpmfusion-free-release-stable.noarch.rpm
#> yum install vlc
#> yum install mozilla-vlc (optionnal)
I'm not a Fedora man myself so hopefully this makes sense to you.
If not I'll see what I can dig up.
Best of luck!
Feb 26, 2009 | fedora Linux Operating System
Envoy 2002 unsteady RPM and engine while stoping
It is your Fan Clutch going. That thing causes all kinds of settings on the computer to readjust as it fails. The fortunate folks that I know that it happened to simply experience a sudden roar of the engine sound,, loss of compression, and just a wide assortment of symptoms. But it was the Fan Clutch. Part only cost about 125 bucks, but after it is installed, a computer download must be performed that is only available from the dearlership. 600 bucks. This should have been a recall item in my opinion,, but.
Nov 25, 2008 | 2002 GMC Envoy
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
