Garden Logo
T
TONY Posted on Jun 13, 2019
HOW TO CHANGE OIL ON LAWN MOWER? - Garden
5 Related Answers
Anonymous
  • 205 Answers
  • Posted on Apr 24, 2009
SOURCE: How do I change the oil in a Sears Craftsman MRS
Tip the mower up on it's side with the dip stick tube on the lower side and dump the oil out. Best to run the mower till its out of gas first.
rwvanlue
Roland W VanLue
  • 486 Answers
  • Posted on Dec 06, 2009
SOURCE: oil change in yard man lawn mower
Some mowers are designed to drain oil out of the dipstick tube. remove dipstick and tilt the mower to allow oil to run out into a drain pan. 2/3 rds of a quart or 20 oz is what to expect.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Jeff Hagemann
  • 430 Answers
  • Posted on Jan 04, 2010
SOURCE: how to change oil in poulan 500 lawn mower
First remove the spark plug wire from the spark plug. Then tilt the handles down to the ground. It helps to have something you can slide the handles under or otherwise hold them down. Underneath the mower deck there will be a drain plug. You are in front of the unit facing it the drain plug will be at about 7-o'clock a few inches from the cranckshaft. It will have a square hole in it. Use an extension on a 3/8ths drive ratchet in the square hole and remove the plug. Be careful not to cut yourself on the blade, I usually remove the blade first and sharpen it while the oil is draining. Loosening the dipstick from the tube on top will help it drain faster. When its done draining replace the plug and reinstall the blade if it was removed. Then refill from the dipstick tube. The unit will take approx. 22 ounces of oil. Do not overfill.
johnnyjcb
  • 3 Answers
  • Posted on Apr 02, 2010
SOURCE: Webb Diplomat 350 Petrol Lawn Mower stops running 10 minutes
The 'DIPLOMAT' series of WEBBs is bad news, its NOT a WEBB! Webb were swallowed by qualcast-atco-suffolk, who dunped Webbs tooling, & dressed up punches & commodores in thin disguises, dumped the briggs & stratten engine for their own alloy job, & charged a rip off premium for the Webb decals!
The qualcast suffolk alloy engine suffers from a WIPAC electronic ignition unit. As it gets old, it fails, sometimes completely, sometimes as it warms up. Once cool, it works for a while again.
Not too hard to replace, but hard on the wallet, £69 genuine, £40 fake! On the whole its not too bad an engine if cared for & oil changed often. better to look on ebay for a cheap used HONDA engine & transplant! R-E-L-I-A-B-L-E !............I did! ( £35 honda gc series, 5,5hp! )
Testimonial: "Thanks very useful information.....Many Thanks"
Anonymous
  • 10 Answers
  • Posted on Apr 12, 2010
SOURCE: we have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Testimonial: "Thanks for the info, you where right on the money.. I finally found it, its on the right side if you were sitting on mower. Thanks again!"
1helpful
Vita 35 classic lawn mower not starting after tilting 2 change blades.
Use some staring fluid to get it going and that will burn off the oil.
Sep 04, 2016 • Garden
1helpful
2answers
Where is the oil drain plug?
Johnathon, some mowers you just tip on there side and drain oil from fill plug into a pan. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Changing Draining Your Walk Behind Lawn Mower Oil
How to Change Lawn Mower Oil
Lawn Gardening Tips How to Change Oil in Lawn Mower
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
2helpful
I need to change oil in my yard man lawn mower. Where is the drain plug? I need to change the oil
Hi, you drain it out of the dipstick filler hole by tipping the mower to that side. Remove the sparkplug cap first as a safety precaution. Hope this helps, regards Phil.
Changing oil in my mtd lawn tractor!! Was oil should I use? Where is the filter? How do I change it?
Most Mower engines have an oil drain plug located at the base of the oil fill tube or dip stick tube, Most mower engines use a standard 30wt engine oil, however, to stay within the parameters of your warranty, use the manufacturers reccommended oil, this info can be located in your owners manuel.
7helpful
2answers
We have 42'' Yard Man riding lawn mower need to how to change oil
2helpful
Oil change
STOP !
Your lawn mower is has a 4 cycle engine
It does not require oil to be mixed with the gas
The oil for the crankcase should be a 10W-30 or 10W- 40
NO GAS IN THE OIL
What you have is a 2 cycle oil that is mixed with gas for most weed eaters, chain saws, ect
Putting a gas/oil mix in your mower WILL severely damage it destroying the main bearings and could lead to an explosion or fire.
Please be careful
1helpful
2answers
I have a troy bilt mower with a briggs & stratton engine. How do I change the oil?
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
1helpful
Change Oil
All lawn mower engines have a drain plug for draining the oil. Look for a square nut on the side of the engine
2answers
Oil drain plug
may be under the blade plate under the mower, usually a plug with a quarter inch square drive, you can use a ratchet to loosen it if it is quarter drive, maybe a half inch drive
Apr 20, 2009 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
