SOURCE: Password retrieval
There?s not much you can do. Try to put the router?s default password which is ?admin? (lower case) and then copy the settings so you can reconstruct them after the reset of the router. Hope it works good luck.
SOURCE: I have forgotten my admin password. How do I retrieve this?
If it is a HDD, then u can connect this to another pc as a slave HDD and gain acess. Else there are software options to retrieve your data...!!! Hoping a good rating from you.
Thankyou
SOURCE: forgotten dl-624+ password and cant get into settings 192.168.0.1
If you’re using Windows, go to Start > (All) Programs >Accessories > Command Prompt.
You should see a command line window. Type in ipconfig and press return. In the output you see, the IP address under ‘Default Gateway’ should be your router address.
If this doesn’t work either, or it is showing the IP address you already tried, please come back to Fixya.
SOURCE: Forgot password to add new computer to router
Hi!
Press the reset button for 10 seconds. It set the factory default
settings. The router will erase all information, the DSL settings too.
After that you can login in with the default password, via web
interface:
http://192.168.1.1
username: admin
password: admin
The default username and password is admin/admin.
I hope it hekos.
SOURCE: dir655, forgot password
Call the company of your router they should provide you with your password
