SOURCE: Daylight Saving Time will not set correctly
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
SOURCE: Hp 2605n Fuser error 50.7
50.7 means that the photo sensor ps6 detected no movement
Open the side of the printer power on the printer and check if the fuser motor moves forward and back. If it does the problem is with the movement sensor or feedback circuitry. If it doesn't its the motor, gear system jamming, motor driver or power supply pcb.
SOURCE: Need insrtuction manual for Cookworks microwave
Hi there, after days of searching the web, I finally FOUND a site with Cookworks user manuals:
http://manualfox.com/link/cookworks.htm
SOURCE: LG600G did not update time for daylight savings time
I had the same problem. I simply powered it off, and powered it back on, and it had updated.
