Lled all the colors and replacement chips before
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
How to reset hP 2600 colour printer chip
When you refill an HP color laser cartridge you need to replace the SmartChip, as I do not believe that there is any way to reset the chip. Any reputable seller of toner would include the chip with the toner order. The are for sale on Ebay
Apr 11, 2011 | HP Color LaserJet 2600n Printer
Kodak 5350 Color Ink Error Problem Solved
Yes the cartridges of all newer printers have chip that indicates the cart ink level, when the cart is empty the chip self destructs.
May 04, 2017 | Kodak EASYSHARE 5100 All-In-One Printer
Hitachi 43fwx20b.replaced both covergence chips how do you align colors
Convergence chips replacement should correct colors alignment itself if alignment was not changed in service menu.
Please make sure both convergence chips are getting supplies that is approx +18 volts and -18 volts.
Let me know if you have additional question.
Thanks.
Apr 25, 2010 | Televison & Video
Epson c62 color ink cartridge says it is empty when i just refill
I use cheap replacement cartridges about 20$ for 3 color/5 black....the printer usually doesnt recognize the cartridges ink level but it still prints......do you use actual epson replacements? If you use cheaper replacements you might have gotten some with dud chips...prob the cartridges fault, not your printer
Jan 01, 2009 | Epson Stylus C62 InkJet Printer
Phillips DLP 50 inch has no color great black and white picture
There is no color chip. What it does have is called a motor driven color wheel. The problem is that the color wheel is no longer spinning to produce color. Replace the color wheel and you should be fine.
Dec 31, 2008 | Philips TV Tuner Video Capture PCI Card -...
Where the conversion chip located on the 5 jcv tv.
the convergence chip is written stk392--- for example
THESE ARE ICS .BLACK IN COLOR AND IS MOUNTED ON METAL HEAT SINK
Nov 27, 2008 | Sony KP-61V90 61" Rear Projection...
HP c5180 tells me to replace cartridge but won't print color
some time first chip is black are bad or not work so any other color are says not work.
u change black chip first.
Nov 18, 2008 | HP Photosmart C5180 All-In-One InkJet...
Power led and russume lled flashing
does this symptom you described happen every time you attempt to power it again? try removing power cord for 2 minutes then reapplying
May 25, 2007 | Lexmark Z53 Color InkJet Printer
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
