SOURCE: Maytag gas Stove MGR5710 bake oven does not work. boiler works
Usually I always find it's the ignightor. They are not to hard to replace. It's #5 on this looooong link
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MGR5710ADW&productCategoryId=0124002&brandId=3048&modelName=GAS-RANGE&diagramPageId=00005&componentDescription=GAS%20CONTROLS&documentId=X2906551&backToLink=Return%20to%20Sub%20Components%20list
Or go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
enter your model number and it'll kind of show you how to get it apart. Good luck.
Scott
SOURCE: brand new gas stove. When oven is turned on there is a heavily gas smell.
There have been reports of gas ranges which have been installed with no leveling legs. (due to various reasons, like a new floor installed, but the counter tops stayed in the same place, so the range surface would be higher than the counter top if the legs were installed) In some cases, this results in an insufficient amount of combustion air for the oven. To test this, put the range up on a set of 3/4 inch or so blocks and try the oven again. Let me know how that went. Thanks.
SOURCE: can't start oven. Stove top works fine. Maytag
top burner burnt out we replaced it with a new one and it still doesnt work please help? Ron
SOURCE: maytag oven wont bake. stove and broiler work and
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
