c
carl gonacha Posted on Jun 12, 2019
Bill counter replacement board - Office Equipment & Supplies
Carnation Money Counting Machine. I need a repair technician for my money counter.
The maker or their dealer network. Ask then for the one closest to your unknown location.
Carnation Enterprises: Bill Money Counting Machines
Carnation Enterprises https://carnation-inc.com Cash counters, bill counters, and mixed denomination money counters with counterfeit detection - businesses love us. Count on us to count your cash!
Carnation All Products
We have carefully designed our range of bill counters and mixed ...
Bill Counter Machines
Key Features: · 1. High-Speed Counting: Count up to 1,500 ...
Carnation CR1500 Mixed Bill ...
The CR1500 Currency Counter and sorter can capture the serial ...
Mixed Denomination Money ...
Currency Counter · Printers · Carnation Bill Money Counting ...
My magner 95 mv is only counting a few bills then shoots em out or just stops? any ideas?
If your Magner 95 MV bill counter was working perfectly and then started having issues after you removed a coin that was stuck and cleaned the machine, there may be a few potential reasons for the problem. Here are some steps you can take to diagnose and potentially resolve the issue:
  1. Inspect for Residual Debris:
    • Double-check the entire bill path to ensure there is no remaining debris or foreign objects obstructing the sensor or the bill transport mechanism. Even a small piece of debris can disrupt the counting process.
  2. Sensor Calibration:
    • Some bill counters require sensor calibration after being disassembled and cleaned. Check the user manual or the manufacturer's guidelines to see if there is a calibration process you need to follow.
  3. Sensor Cleaning:
    • Ensure that the sensors responsible for counting the bills are clean and unobstructed. Use compressed air or a specialized sensor cleaning kit to remove any dust or dirt.
  4. Check the Bill Condition:
    • Make sure the bills you are trying to count are in good condition. Crumpled, torn, or heavily creased bills may not be processed correctly by the bill counter.
  5. Check the Bill Thickness Adjustment:
    • Some bill counters have a feature that allows you to adjust the sensitivity to different bill thicknesses. Make sure this setting is correctly adjusted for your currency.
  6. Reassembly Check:
    • Ensure that you reassembled the bill counter correctly, and all parts are securely in place.
  7. Software and Firmware Updates:
    • If your bill counter has software or firmware, check if there are any updates available. Outdated software can sometimes lead to operational issues.
  8. Inspect for Damage:
    • Check for any visible damage to the bill transport mechanism, belts, rollers, or sensors. If there's physical damage, it may need to be repaired or replaced.
  9. Professional Servicing:
    • If the problem persists and you cannot identify the issue, it's a good idea to contact the manufacturer's customer support or a professional technician who specializes in repairing bill counters. They can perform a more in-depth inspection and diagnosis of the machine.
Remember that bill counters are precision instruments, and any misalignment, sensor issues, or physical damage can affect their performance. It's important to address the issue promptly to ensure accurate and reliable counting of bills.
It shows erro 124-315
The serial no., product no., and billing count are stored at three locations; the MCU NVM PWB (IOT), the SEEP ROM (SYS1) on the Backplane (BP) PWB, and the ESS NVM PWB (SYS2). This procedure allows the data in all three locations to be synchronized in case of replacement of one of the PWBs, or due to data corruption associated with one of the following faults:
  • 124-324 (3 Billing Counter Mismatch)
    124-325 (1 Billing Counter Mismatch; Unable to recover Billing Counter during recovery)
    124-312 (Product No. Mismatch)
    124-313 (Serial No. Mismatch)
    124-310 (Product No. Failure: Not initialized)
  • 124-311 (Serial No. Failure: Not initialized)
Procedure
  1. Enter UI Diagnostic mode ( Accessing UI Diagnostics).
    Select Adjustment/Others.
    Select Machine ID/Billing Data Settings.
    Select a PWB with the correct data.
    Select Start.
  2. Enter the correct serial number in the Serial Number screen and then select Confirm.
How can we get the counter to know when a different bill is mixed in
We consider the semacon a throw away machine. That being said, the s-1625 is not capable of detecting different bills. It is just a unit counting machine. It does have the option of counterfeit detection using magnetic or UV sensors if you have that version. A true counter that can find the wrong bill in a pack is at least a $3,000 machine and are very nice. Good luck.
How o we get the s-25 to seperate bills?
It is not capable of separating bills. You need a different machine to do that. Like a Shark 100N for example. Good luck....
Workcentre 7238. What causes error code 124-315?
Procedure
    Select Start.
2helpful
I have a xerox 7428 with error 124-315 how can i fixit
Procedure
    Select Start.
2answers
Instruction Manual for Brandt 8625 Bill Counter Money Counter
I found this site while looking for manual for brandt bill counter, but it seems to be about washing machines. Does anyone have a manual for the bill counter?
k24674
ADMIN Andrew
ADMIN Andrew
