SOURCE: I am looking for fender for honda fg100 rototiller?
If It is a Honda FG100 like in the title the part number is 65141-V06-003
If it is a FG110 like in the description the part number will be 63411-V25-000 FENDER, RR. and 65141-V25-000 FENDER, FR.
SOURCE: Honda FG100 Tiller - Tines wont move
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
SOURCE: Honda FG100 tiller will not prime, filter replaced
Well if the unit has fuel than it should prime unless the primer bulb is damaged and unable to force air/gas through the line. This is definetly a fuel issue, I would remove both the line from the tank to the carb and carb to engine and clean them thoroughly.
When you press the bulb the carb should shoot gas from the unit when disconnected. If this isn't happening your clog is here. If it does eject gasoline than your clog is the clear line which sometimes collects sediment if the gas is poluted.
SOURCE: the tillers start working and right away stops, the tiller still runs just the tillers don't
check the shear pins on the tine shafts
