I am in need if the plastic speaker stand base
2 Suggested Answers
SOURCE:
  • 1127 Answers
SOURCE: The base of one of
try on local electronics store, they help you the best way. Or replace connector or replace all.
Posted on Dec 15, 2010
I need help removing the stand to my ASUS VH197D LED monitor so that i can attach my wall mount.
For the ASUS VH197D LED Monitor, turn it upside down so you are looking into the base of the stand. Squeeze the plastic tabs to unlock the base and pull. This will remove enough of the base to make it wall mounted and you can quickly attach the base if so desired. If you want to permanently remove the base and stand, remove the two screws that are now visible after the base is removed and pry out the plastic stand. This will break it off at the hidden screws. You will be left with a short metal stub that can be folded in.
Aug 01, 2011 | ASUS VH197D LCD TV
Please help me for may led monitor asus vh197d how to remove the base to put in to a wall tns
Mar 30, 2011 | ASUS VH197D LCD TV
I have a 42 in. Vizio Galleria and need to remove table top stand so I can wall mount. How do I remove base stand?
1. Unplug all of the cables and cords from your GV42L FHDTV10A.
2. Place the GV42L FHDTV10A face down on a soft and flat surface (blanket, foam, cloth, etc) to prevent any damage to the TV.
3. Pull the stand cover off by squeezing the sides to release the retaining plastic tabs.
(This is probably the trickiest part to find this, just feel around and don't be too rough with the plastic)
4. Remove the four (4) screws (screw's specs: M4, 0.7 Pitch, 15mm long) so that the stand base can be removed.
5. Gently remove the stand base
6. Now, the GV42L FHDTV10A can fit securely to a mount (sold separately) by utilizing the mounting holes in the center of the back panel of the TV. Please make sure to read the instructions of your specific mount to properly hang the GV42L FHDTV10A
Mar 13, 2011 | Vizio Gallevia GV42LF 42 in. LCD...
How do I remove the base stand fro my Neovo F-17,
You need to remove the two plastic covers the cover up the hinges mounting screws, which are attached to the back of the monitor.
Oct 26, 2009 | Neovo F-17 W (White) 17 in. Flat Panel LCD...
How do you the base stand on the Samsung T220?
I tried to pull the base stand out - no luck. I tried to wedge a screw driver in - no luck and it looked like the screwdriver could damage the plastic if pushed harder. I finally used a wide metal paint scrapper. It went in where the screwdriver would not go and moved to base enough to allow it to pulled out the rest of the way.
Oct 18, 2009 | Samsung ToC T220HD 22 in. LCD HDTV Monitor
Need more volume on computer speakers
Buy yourself some stand alone speakers, a base & two side speakers, they cheap these days, base speaker has buit in amplifier & plugs into mains, or get surround sound 5speakers & a base, again mains powered, loud enough to annoy neighbours on full. Built in monitor speakers are renowned feeble tinny sounds. Right click speaker icon, bottom right, on your desktop toolbar, open volume control, ensure volume sliders set to max.
Oct 02, 2009 | ViewSonic VX910 19" LCD Monitor
Logitech Z-5500 satellite speaker stand broken
i do not know if logitech sell replacement stands but
http://www.crutchfield.com
and
http://www.best buy.com
both sell good speaker stands. you may be able to find one on there.
Feb 25, 2009 | Logitech Z-5500 Computer Speakers
How do Iopen the case of an HPvs17x monitor?
The Capacitors on the power board are usually the reason for failure of an LCD. If you open the HP VS17 ( I can provide an exhaustive step by step If I have to) remove the five screws for the power board ( larger of the two boards) and look for an area where there are 4 caps (see pic). Look for exploded, popped up, bulging, or leaking caps and replace with the same or slightly higher tolerances. The one I replaced last night were (2x )1000uf25-50volt and (2x) 470uf25-50volt. Check the rest of the board for similar issues and replace as needed.
Jan 21, 2009 | HP Vs17 17" LCD Flat Panel Monitor
How to Remove the Base
I have an Olevia 42" TV. I was able to remove the base by removing 16 screws on the back side. They were arranged vertically in 4 sets of 4. The screws go through the back panel, through the base and attach (without nuts) directly into the inside of the TV. After removing the 16 screws the stand simply slides out.
I tried removing two screws underneath the base area. They were small screws and were a pain to remove. I thought I would try that first instead of removing 16 screws but that did nothing.
Dec 10, 2007 | Olevia LT42HVi 42 in. LCD Television
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
