Disconnect the negative battery cable.
Raise and safely support the vehicle.
Remove the drive belt shield at the right wheel well.
Remove the drive belt.
Remove the drive belt tensioner mounting bolt.
Remove the drive belt tensioner.
https://www.ronmowers.com/brand/toro
SOURCE: My belt tensioner pulley broke at the bolt that
You should only remove the drive belt shield if you raise the car. Below are step-by-step instructions per the repair manual.
Drive Belt Tensioner
Removal & Installation
To Remove:
To Install:
SOURCE: I need a toro z4200 drive belt diagram as my belt
I have the same problem and juts figer that out and put back on but still not working,
SOURCE: how do i change the
Run new cable under right side of mortor put cable through throttle brake bracket hook end into slot. Then run other end to handle and hook in slot.
hope this helps.
Joe
SOURCE: 2002 KIA SPORTAGE. REPLACING FAN BELT NEED RO
Hi, there are up to three belts if you have A/C. Each belt has a tensioning system. Diagrams and instructions from autozone.com are paste below. Please let me know if you have any questions, and thanks for using FixYa.
A/C belt:
Alternator and fan belt:
top view of generator belt adjusting bolt C:
Power steering belt:
A/C Compressor Belt
To install:
Alternator Belt
To install:
Power Steering Pump Belt
To install:
