Question about Android Apps
I am having idling issues with my opel corsa 2003 1400i hatchback, the idling stays high but also fluctuates during a stop at the robot, please advise
Leandra
SOURCE:
  • 1348 Answers
SOURCE: 1993 Mazda Mx3 Revving high/Fluctuating during idle.
there is either a vacuum leak,or a valve on the throttle body called an iac that is bad. it is the idle air controller.alot of mazda have that problem
Posted on Oct 23, 2009
  • 1026 Answers
SOURCE: my car starts, but it wont stay running
idling jet carburette
Posted on Feb 16, 2010
  • 248 Answers
SOURCE: Accidently sprayed carb cleaner in throttle body
try disconnecting the neg batt terminal for a few mins....take the car for a spin afterwards so the computer can re-learn what it is suppose to know....hope this helps
Posted on Mar 05, 2010
SOURCE: opel corsa 1.4i car cuts
My Opel corsa Lite 1.4i, 2005 model cuts off when idling or stopping. I've replace the ignition coil as it was suggested but the next day the problem continued. I've replace plugs, filters, ect. When I'm approaching a place where i have to stop i see lights on dashboard coming out and the engine goes off if i stop or if i put the second gear it kicks again. Please assist as none of mechanics in my area know where to fix now.
Posted on Apr 18, 2011
alicantecoli
  • 22484 Answers
SOURCE: My Opel Corsa dies down during driving, it will only start again after 7 to 10 mins, l have no clue whats happening.
No idea offhand to be honest i would need my head under the bonnet to know what wrong .could be anything from the gauze filter in the fuel tank on the bottom of the fuel pump becoming chocked up and leaving the car allows it to drop away to a faulty pump overheating or the contacts ,maybe even a ignition module overheating ,Best advice is ask a local mechanic to have a look for you as normally these early opel corsas with the 4 cylinder engine are bullet proof they are even valve free if the timing belt snaps .
Posted on Jan 31, 2012
What is a problem my opel corsa lite 1.4 2006 model rev high when im stoping at the roboot or stop sign even if im not moving after i start rev go high to 200 and it drop down and up again
As long as the idle air control valve is working, ( I assume this is what you replaced, I would first check to make sure it is operating correctly), If it is, then Id begin searching for a vacuum leak
Jun 08, 2016 | 2006 Opel Corsa 1.4
Opel corsa 1400 has no idle
This car is a one point injection motor.So there is a screw
to adjust the revolutions. If you cant find it ask a mechanical
to show you,
Feb 16, 2014 | Opel Cars & Trucks
My opel Corsa lite Revs itself while idling or when I press the clutch while driving. The rpm stays @ 2.. What is the cause of this
A similar thing happend to me turns out it was the idle rev cold switch thing>
basically the switch which provides more fuel and revs when the car is cold, so that when you start the car it doesnt just die off.
the switch itself is a bit mechanical and is perhaps jammed on the full on position. If it happens more when the car heats up. then it is this switch.
what you can do is start your car one cold morning and see how high the revs are, if its still high then its probablly not the switch
Mar 27, 2012 | 2004 Opel Corsa 1.3
Opel corsa 1.4i car cuts off when idling what is problem
Nov 30, 2010 | Chevrolet 1500 Cars & Trucks
Android Apps Logo
118 people viewed this question
Top Apps Experts
Brett Duxbury
Brett Duxbury
Marvin
Marvin
Are you an App Expert? Answer questions, earn points and help others
