I checked printer lid. checked toner. the printer is printing documents properly through computer but not coping properly. it it copy a few part of page and print whole page black. it might be scaner problem. kindly help me to ridout of this problem i am to much worried about it. waiting for your reply. Regards Aamir Subhani
SOURCE: My Canon Laser Shot Printer only prints black page only. Please help.
Have you tried a different print cartridge? Usually a black page from a laser printer is caused by the drum in the cartridge not recieving the correct voltage. Try borrowing one from someone if you don't have another to try.
SOURCE: scanning document leaves streak down right hand side
hmm this has happened before
make sure it is sitting straight and cleaning it might help
SOURCE: Printing only one quarter of page when copying
Make sure by checking if your lamp scanner light when your doing a copy ??? This look like a scanner problem !
Make sure to that your glass is clean !
SOURCE: Red not printing red on whole document
I think this will fix your problem. http://www.reeves-hall.net/tech-gadgets/fixing-washed-out-colour-on-hp-color-laserjet-2605/
SOURCE: The printer shows low on black yet prints solid
Yes it start giving the warnings if it still have the ink just to make sure you get the new cartridges well before it gets completely dried
Your machine offers the following ways to scan an image:
• From TWAIN-compliant software: You can use other
software including Adobe Photoshop Deluxe and Adobe
Photoshop.
• From the Windows images Acquisition (WIA) driver: Your
machine supports the WIA driver for scanning images.
• From the Samsung SmarThru software: Launch Samsung
SmarThru and open Scan To to begin scanning.
NOTE: To scan with your machine, you must install the
software.
Loading document
You can use the document glass to load an original document
for copying and scanning.
1 Lift and open the document cover.
2 Place the document face down on the document glass
and align it with the registration guide at the top left
corner of the glass.
3 Close the document cover. Be careful not to move the
document.
NOTES:
• Leaving the document cover open while copying may affect
copy quality and toner consumption.
So, basically, if you have the software installed. Open the Smarthru software, load your original onto the glass, face down, and close the lid. Select scan, the software may provide you with a preview of the scanned image. Once you scan the document, you must save it to a location on your hard drive, often it is called "My Scans" in your "my documents" file.
I hope that this is helpful. I have attached a link directly to the Samsung website manual for your model
http://downloadcenter.samsung.com/content/UM/200912/20091211171126218/Guide_EN.pdf
