SOURCE: Akai plasma tv 5 blinking red lights PDP4298ED
Have you guys checked out my solution in the troubleshooting and support for this same Akai model?
SOURCE: standby light blinks for 6 times
Did you get this solved yet? Six blinks usuall meand thermal fuse. I can look it up if you still need help.
SOURCE: Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
SOURCE: The screen won't turn on. The tv just clicks and
The power board ic coverter it dead.
U need to replace the power board.
U can go the web and buy this board changes
or get the tv repair man replace part and labor $575.
SOURCE: Digistar PH-4210D Black Screen
Plasma tvs do not have "back lights" LCDs do. you probably have a bad driver board along with the upper or lower buffer board or maybe both, best to have a tv shop look at it.
