D
Dahlia Taylor Posted on Jun 11, 2019
My indurama stove has military time how do I change to regular time
5 Related Answers
Anonymous
  • Posted on Dec 06, 2007
SOURCE: Getting the clock off military time
With the sytem off, hold down the Alarm Setup button and the On/Off button to switch between 12 hour (AM/PM) and 24 hour (Military) time. If you need the manual go to
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/guides/music_system.jsp
Anonymous
  • Posted on Mar 03, 2008
SOURCE: Bose Clock
To set AM/PM (12 hour) or Military (24 hour) time - With the system off, hold
down Alarm Setup and press On/Off to switch between AM/PM (12 hour) and Military
(24 hour) time formats.
Ekse
  • 13435 Answers
  • Posted on Jul 13, 2009
SOURCE: How to set the time on Athletic Works watch
Press and hold the lap/reset button for at least 5 full seconds. You should see the word "SET" appear in the dispaly. Push the Mode button to change from alarm to date to month, time, etc.. Use the start/stop button to change the numbers.
Anonymous
  • 35 Answers
  • Posted on Aug 09, 2009
SOURCE: have ds time from military to regular
you have to go to the main screen then at the bottom of the screen there will be a small DS click that and you will hit the menu
digritz
david mcclellan
  • 530 Answers
  • Posted on Nov 23, 2009
SOURCE: how do i change the time back to regular rather
This is for the Bose Wave Radio. If you have a different model just let me know. I also included a link to the manual just in case you don't have one
Hope this helps.
To set AM/PM (12 hour) or Military (24 hour) time - With the system off, hold down Alarm Setup and press On/Off to switch between AM/PM (12 hour) and Military (24 hour) time formats.
http://www.bose.co.uk/GB/en/images/Wave%20Radio%20CD_tcm6-4104.pdf
How do I change the time from military time to back regular time on my Delonghi COM530m coffee maker?
It has always been Military time.
https://www.manualslib.com/manual/2073018/Delonghi-Com53-Series.html?page=7#manual
and from DeLonghi direct
The clock on my BCO combination machine is military time. How can I change it? All BCO's units are designed with a military standard and it is not possible to change it.https://www.delonghi.com/en-us/faqs/search?q=%20Delonghi%20COM530m%20military%20time..
1helpful
2answers
How do i change from military time to regular time?
Just press some buttons on your Audio Player and Recorder.
If your stated 'make model (what it is)', it would help a bit!!
Or you could Google
make mode manual
or
make model change from military time.
You know that Google knows everything right?
To be able to change to analog time from military time
Go to your events/calendar. Click the little settings symbol there. Then uncheck 24-hour time and save. How do I change my clock settings from military time to regular time.
just found this on the internet dont no if this will help you out if not let me no.
Why does time keep switching to military?
you have it set on 24 hour time instead of 12 hour time
it will change over at midnight to military time as that is when the 24 hour period ( military time ) starts
1helpful
Rca led tv shows military time is there a way to change it to regular time?
Having the same damn problem it's not in the settings menu or I would have changed it would need to know how to change this to regular time it's very annoying
This is controlled by hardwired switch (12/24) OR digitally during menu setup sequence.
30helpful
2answers
 Grubhead
Grubhead
SmartAviator
SmartAviator
