Seiko Smart Label 240 Thermal Printer Logo
Posted on Nov 27, 2007
Smart Label Printer 240
All of a sudden my label maker decided not to print at the beginning of the label. It positions itself at 3/4 of it and I find myself wasting a label everytime. I've partly taken it apart and I cannot find any label stuck inside.
Any suggestions?
Thanks,
Geneviève
  • JeannieRiver Jul 10, 2008
    All of a sudden my Seiko Smart Label Printer decided not to print at the beginning of the label. I'll have a 4-line address, but it doesn't print the first 2 lines, starts printing the 3rd line. I've checked all of the settings against another label printer at another desk and all of the settings match. I've rebooted and unplugged, etc. Nothing helps. Any suggestions?
    Thanks,
    Jeannie
  • Anonymous Mar 20, 2014
    SII Smart Label Printer 440. Just sits and won't do anything or does one and no more. Today it's asking how will it be connected to this computer? It's never worked consistently since I got the Windows 7.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2076
Points
Check your labels. Are there black "sensor marks" on the back of each label? That's apparently how the printer lines itself up.
A
Anonymous
Start with unplugging it and rebooting pc to see if it will reset itself
What in the world!! I have the Smart Label Printer 450, it is not advancing the label, and the power button is flashing. It will not print a label at all at this point, and when it will end up printing a...
Unfortunately, this is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. This means your Smart Label doesn't think its wasting labels, it's just trying to run through what it considers to be unsuitable labels as fast as it can. If you're only printing one label at a time you can recover some labels by correctly the label's line up after each label you print but there's nothing you can do so that your printer will properly advance its current labels.
Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
Smart Label Printer
If the answers above don't work check your AC adapter with a multimeter to confirm its output voltage. If the voltage is off by more than 1 volt you will need to replace your network driver
15helpful
SMART LABEL PRINTER 200 WINDOWS 7 DRIVERS
Smart label drivers (and every other driver related problem) can be easily found here: Driver Update
have a nice day
Dennis
What is a label maker used for?
Label makers are used to develop the text design to print on labels.
For eg, in retail industries, they make labels(stickers) for printing Price tags along with item description and barcodes.
Label makers is a software which enables the user to frame their text position, fonts, description etc..! with which they their desired design in labels via a label printer.
hope we made u clear.
if you need info on label makers.
please see our site www.trridevlabelss.com
After each label I print the printer automatically advances 3/4 of the way through the next label. Is there a setting to stop at the end of each label?
I don't know the particulat incantations for this printer, but it sounds like the "form length" or "label length" is not set correctly. Normally the printer will advance to the beginning of the next label once the printing is complete. Check the menu or setup program for the label length.
Let me know if you can not find this and I'll research the exact commands.
Thanks,
Dan
Too much tape
Hi, it seem your label maker is set to the last(amount) of labels printed. Go to: Print Labels, click; Number of Labels; clear to set to (1) Label. That should stop the run off of labels. Thanks paul70f9
3answers
How do I set the printing preference for my smart label printer 240--I have windows xp
Go to the Start, Settings, Printers. Select your printer, the set it as your default printer.
You can also get to the printer by way of the Control Panel.
4helpful
Label not advancing to tear-off perforation
Try this to have the printer auto-sense the size of the labels:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
Top Seiko Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
