SOURCE: treo 650 won't turn on
Could be a dodgy power connection this seems to be happening a lot at the momentif you look at other threads here.
Kevan
SOURCE: Magellan Explorist 500 LE Power
eXplorist units have also some hidden and service functions. Like, if unit is off, you can to press:
- IN + PWR - to full selftest of unit (screen test, keypad test, NMEA test)
- OUT + PWR - to serial port test
- ESC + PWR - to burn-in process
- LIGHT + ENTER + RWR - tp uploading of new firmware
- NAV + PWR - to call Service Function window (see below)
- NAV + MENU + PWR - to force power off, equal remove batteries.
- GOTO + OUT + POWER - clear memory and set all settings as default.
IN + PWR helped to power up my unit.
SOURCE: Garmin C530 won't power up. I fully discharged
How old is it and does it get quite a bit of use
If so then consider replaceing the battery
Ebay has a good selection from a wide range of reputablesellers and very good prices
Check Here
SOURCE: my garmin won't turn on. I have tried the plug in
it does have an internal battery, but that normally wont prevent it
from turning on unless the battery is defective.
plug it in to the usb cable on your computer for a while (normally it will start right up) then slide to power switch to the on position for about ten seconds.
if that fails, press and hold the lower right corner of the screen and then slide the power switch to the on position while holding the lower right corner of the screen and follow the directions once it starts
i can give you something else to try before you go and spend money on a battery...a battery should be the last thing to do, even though it will more often then not fix the problem thats tempory..
if it turns out you think you need a battery, i will point you to one with instructions on how to change it.
bill
