Probably the grease seized due to age and unuse.
May need to use (gentle) force to get the two binocular halves to move. If they are truly frozen in position, the only other fix is to disassemble the two halves and regrease.
I've had a pair that were stuck in position like yours, and it took some force to get them to move. Once I had them freed up, I kept moving back and forth until they finally could be adjusted using force. (They never truly became easy to adjust. )
Probably set up to accommodate users from the manufacturing nation.
SOURCE: need to find someone who knows about repairing
I am an avid birder and sent my Zeiss and B & L binoculars to Larry at reichinstruments.com - his prices were great and service was quick. He restored them to A1 order and I'll use him again. I recommend him highly! Nice guy to deal with.
SOURCE: hinge on binoculars is too loose
there is a hinge nut at the bottom of the hinge..sometimes you have to turn of the cover or peel back the rubber to get at it
SOURCE: I have a Bushnell 8 x 21 binocular. The
This page explains how one person tightened the hinge:
http://www.birdforum.net/archive/index.php/t-95728.html
This is all I could find on fixing them. There are always tricks, hidden screws, and inobvious things the manufacturers do to make them sturdy and pretty.
Good luck, and hope this helps.
Check this response and see if it might apply to you too:
http://www.fixya.com/support/t101778-binocular_double_vision
Good luck.
