Go on line to locate printer software - install new software to recognize printer. https://www.6ya.com/callphilipforhelp
SOURCE: offline problem...won't print
Go to start>settings>control panel>administrative tools>services.
Scroll down the list to "print spooler." Right click on this and choose the "restart" option.
This should fix the problem and print any stuck print jobs.
SOURCE: My printer (MFC-490-CW)print status is offline change online
If you want to make it online, than make sure it is on and connected to your computer, Once you are sure about this than
Go to control panel than Printers and Faxes
There You need to right click on printer and than Use printer online
IT will Put you printer back online.
SOURCE: Belkin FSD7050v4 driver for Windows 7
just installed my belkin wireless g usb adapter on windows 7 64 bit down loade driver from belkin right click run in compaterbilty mode windows vista service pack 2 and install
Testimonial: "It's been a while but i did get it working and I believe this is what i ended up doing. thanks."
SOURCE: webcam Tvisto ACM-366 doesn't work on Windows 7
Try running the webcam program in 'compatibility mode'
SOURCE: HP Deskjet 3420 driver issue in windows 2003 x64 edition
Driver download link: HP DeskJet 3420 Printer Driver
Check that the printer is online using the following steps:
VERIFY THE BROTHER MACHINE IS POWERD ON AND THERE ARE NO ERRORS
For Windows® XP and Windows Vista® Users:
Right click on the icon for your Brother machine and choose Resume Printing. (If the menu reads Pause Printing, there is no problem in the printer status.)
For Windows® 7 Users:
Double click on the icon for your Brother machine => See what's printing => Printer => Pause Printing (Take the checkmark off.)
If this does not solve the problem,
Double click on the icon for your Brother machine and choose Printer => Cancel All Documents.
Double click on the icon for your Brother machine => See what's printing => Printer => Cancel All Documents
