Highly probable . Get it fixed . To dangerous
Most likely it is running too rich air fuel mixture... be sure choke is off (knob all the way in).
If choke is completely off then likely carburetor fuel pump/metering is fouled. Try a fuel treatment, Seafoam (or other). Follow instructions, measure don't guess.
SOURCE: Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
SOURCE: Pool heater pilot lights, goes out when heat called for
No, that would just cause you to have huge flame. There is another high pressure switch located next to the flame sensor/ pilot genator that can cause this problem it is the size of a quarter and is screwed down with 2 phillip head screws
SOURCE: 1997 volvo850gtl extreme smoking from exhaust
black smoke ( burning too much gas)
blue smoke (burning oil)
white smoke ( burning coolant)
hope this helps
SOURCE: i have a 3000 watt magnum energy sine wave
I'm sorry that I can't help you, but if you're in a hurry, you can visit the Magnum website at: http://www.magnumenergy.com/Service/Servicefront.htm and try to find your model's online manual and search troubleshooting advice or you can email customer service at
[email protected] and they should at least be able to lead you in the right direction.
A few questions: Does this problem remain even when there is at least a 10+ watt load on your system? is your Magnum in a hot environment? Does your inverter feel extraordinaryily hot? Have your batteries outlived their lives? Have you cleaned all the connections? Even if they 'look' like they don't need it?
All the best to you.
SOURCE: kipor generator starts ok but will not provide electricity to apppliances
first check the circuit breakers if there ok the problem is inside like over heated parts
