Can you used reynolds wrap to cover the pan
Yes foil can be used to control burning on top of chicken
. https://www.6ya.com/callphilipforhelp
SOURCE: This is an electric convection oven
I am by no means an expert, but I believe the only thing differenty in a convection oven vs a regular oven is that there is a fan to conduct the heat quicker and more evenly. It has to do with heat tranfer rate. I can't imagine why aluminum foil would cause any problem.
SOURCE: Foil drip pan melted to the bottom of oven? Will it burn off?
IF YOU CAN REACH IT IN EASY SO YOU CAN USE A SUITABLE TOOL LIKE TWEEZER
BUT REMEMBER IT MUST BE OUT OF WORKING COOL CONDITION FOR 1 HOUR MINIMUM TO AVOID SCALDING.
THANK YOU
SOURCE: Wearever chicken bucket
I used my just last night. Brown the pieces in the hot oil for about 2 min. For 6-8 pieces cook for 15 minutes once the vent jiggles. Smaller pieces cook for 12 min.
SOURCE: how do i get an aluminum foil pan stuck from the
You may be able to get it opff with the oven hot. Whatever is holding it was liquid when hot before, so should at least loosen enough for you to remove it.
SOURCE: The top plate inside the microwave sparks while
The wave guide could be dirty or damaged. Dirty oven interior can also cause sparking. The wave guide is probably not dirty if it's not on the interior of the oven . Some are behind the interior wall .
