SOURCE: instrument panel and interior lighting not operating, 2004 F150
sounds likke u got grounding problem with ur wiring. if ur fuse pops wen u install a new fuse. this means ur grounding wire is cut or touching with metal. if doesnt pop,then it is ur power wire that is cut or touching the metal (grounding out)
SOURCE: instrument panel will not come on
Welcome to the club! Have a look at the "blank dashboard" posts. Hundreds of cars out there with same fault, Renault will charge £500-£700, some firms do "mail order" repairs for £200 - and please email Watchdog, Renault need to start sorting this out! Lots of us are doing the same. Try ECUtesting.com or Cluster Repairs UK and have a look at renaultcustomer.com/ or threads on howtomendit.com.
SOURCE: Where do I find the fuses under the instrument
The 2004 1500 hemi does not have a fuse box inside the cab, they are all under the hood in the fuse box near the battery. Hope this helps
SOURCE: WILL A BAD FUSE #48
Yes, this usually called the Mega fuse, it supplies all power to the rear fuse panel.
SOURCE: WHere do I find the
O4 VIBE...Replaced the motor and it cranks right up but when you put it in gear it dies...even after warming up for a long time...after 10 to 15 time of this it you can finally keep it going and after it runs for a while it is fine. Let it sit for a couple of hours though and you have the same problem again. Also the dash lights will go out every now and then and it is completely black. Help needed please.
