That trans should take 4.2 quarts of John Deere lo-visc hygaurd.With both plugs removed from bottom of trans as well as the bigger black plug on the front side of trans,it should fully drain in about 5 minutes.Dont forget to unscrew the black fill plug from top/left side of trans so it can vent.Your book may say not to remove it but it's a misprint.When you go to fill trans dont install fill plug until oil is at top of threads,then install plug/cap.Continue to fill trans through white plastic tank until its level with lines.
sounds like your linkage is disconnected, With the tractor off raise the seat and back panel (if possible) and work the shift and look for failing linkage.
Yepp, i can help you! There are 5 diferent ones of that GT225
I dont know witch one you have so i'l give all five here:
HEDGETRIMMERWEEDEATER -->
GHT225 ( 952711803 )
Manual: View
Parts Manual: View
GHT225 LE ( 952711803 )
Manual: View
Parts Manual: View
Manual: View
Parts Manual: View
Manual: NO MANUAL AVALIBLE
PArt Manual: View
Manual: View
Parts Manual: View
