I want to use the digital out cord to connect my Boss BR1180 to my computer to perform live music on Webcam. Not sure what size I need to getthat will fit the Boss BR 1180
SOURCE: I have a BOSS BR-1180
No You Or Your Buddy Just Completely Erased The Hard Drive.
www.Myspace.com/CrossRoadsToNowhere2007
SOURCE: I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
SOURCE: MY Boss br 1180 ,disk error
before you go out and buy a new hd try intializing your system.
unfortunaly you will lose all saved info, but you will either way. this test may save you some money.
with your 1180 in the off position press and hold the track 5 button below the fader and the redo/undo button that is just to the left of the rotarty knob and below the power button. while holding these two buttons press the power button and continue to hold the track 5 button and the undo redo buttons untill the test menu is showing. its takes about 15- 30 sec. in the test menu rotate the value knob till you see 23 initialize HDD and press ok. this process may take up to 30 mins. if this doesnt fixya then contact roland for a replacement.
SOURCE: What do I need to burn a cd from my pc with the br 1180
This Is real simple grab a cable that goes from rca jacks to a headphone jack then plug the rca jacks into the br-1180's audio out jack and then plug the other end into your computers mic port.
Download Audacity From www.Audacity.com and then use it to capture you audio and then you can burn that when complete.
Its real simple I do it all the time even though I have the br-1180cd the cd burner burns real quiet so I don't use it. The cable can be bought at radio shack, best buy, wal-mart and I have even seen them at 99 cent only stores.
If you have more question let me know This Is my main unit so I know a lot about it.
Sincerely,
Michael Scott
SOURCE: No CD writer for Boss BR-1180
Hey mike yeah you can hook a regular cdr drive to the ribbon but the problem is if its not a slim it most likely wont fit inside the unit. Also the built in c.d r is way over rated mine has it and I still bounce it all onto my computer and then burn it from there. The one on the br-1180cd burns very quiet.
