Refrigerators Logo
t
tom rivers Posted on Jun 10, 2019
Ed22 frig temp is 60and freezer is 20 what is wrong
fpreston
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jun 15, 2019
fpreston
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
Helped
4159
Points
14
Usually, this is caused by a stuck or bad evaporator fan. There are several other possible causes. The first thing that comes to mind is low freon.
5 Related Answers
freetek
Steve Allison
  • 5569 Answers
  • Posted on Sep 13, 2008
SOURCE: Sub-Zero temperture fluctuation
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be an issue with Sub-Zero.
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Jun 18, 2009
SOURCE: The Frig Side temp. is 51 and freezer side temp.
I need you to check a couple things for me before we go to far. Is frost building up in freezer back panel? Are all fans inside and outside of the refrigerator. That refrigerator has a control board and we may need to have a look at it. The control board is AP4139120
But I need to hear from you first before going further. Thanks, Sea Breeze
Anonymous
  • 363 Answers
  • Posted on Jul 22, 2009
SOURCE: My GE Profile bottom freezer and frig's temps are also up..help
has a FF error shown up on your display. If so that is your freezer fan, and if not it still might be the FF motor is running to slow.
jamie
  • 1810 Answers
  • Posted on Aug 03, 2009
SOURCE: GE Profile Artica freezer temp continues to rise
try replacing the thermostat and the defrost timer
Anonymous
  • Posted on Aug 07, 2009
SOURCE: Freezer not maintaining temp
sounds like the evap thermistor took a ****. in the back of your freezer you have cover that sits over the refrigerator coil. under this coil sits a heater element that is turned on and off to defrost the refrigerator coil based on how long you've had the door open. the evap thermistor reads the temp inside the freezer.. close to the refrigerator coil.. and tells the heater element to turn off after it reaches a set temp where it can be sure that the ice has melted off the refrigeration coil which is about 60 deg. if your thermistor has taken a ****.. your heater element will only shut off based on the "fail safe" time (which is based on how long you've had your fridge door open) leading to a hot freezer.
i suspect your at home more on the weekend.. inside the fridge.. getting cold beers.. and that is why it ends up hotter on the weekend.
Cheers!
Freezer does not get to 0 temperature , , , frig portion stays at set temp. The freezer temp varies up and down and usually is at 16 to 20 degrees.
Make sure that the cooling coils are free from dust bunnies and other debris. Plastic bags are a big problem.
1helpful
Amana bottom freezer temp 16 below. Turn temp down a little temp goes to 20 above
With that kind of spuratic actions I would strongly lean toward that the temperature control, also know as the cold control , is probably malfucntioning. Before I can 100% call that fact I would need more inforamtion, model number the most important. Also, a description of how the machine looks on the inside, like frost on the wall, ice, etc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
My temp on the frig temp is not working
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Freezer is at 38 currently has been climbing all day
Hi!!! Yes its normal dont panic just relax and have a cold soft drink..Nothing is wrong with your frig..Remember defrost cycle is 15-20-or 30 minutes depending on the frig..Good luck..Its all normal..
2helpful
Bottom,(refrigerator) isn't cooling at all. the freezer is 20 below zero. what's wrong?
The thermister is located in the fridge. Verify it is clipped to the metal fin Think of this as a knob control move it up and down to control the fridge temp. If this does not help most likely you need a new thermister.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
