What model styli do I need,to play 45, 331/3 and 78rpm records on my Tevion model P50708 turntable?
    Top Expert:
  • 935 Answers
Dont try to match the stylus based on the brand and model alone. It's better to match based on the cartridge brand and model.
Read the information on the website as to how to select the correct stylus for the 45 & 78 formats. Email them with all the information you can find a d they'll fix you up properly.
https://www.turntableneedles.com/How_to_find_the_right_turntable_needle
Posted on Jun 19, 2019
    Sergeant:
  • 469 Answers
Stylus should be same for all. It's the speed settings that make the difference. If you player does not have dial with 33/45/78, then you wont be able to play them.
Posted on Jun 10, 2019
Testimonial: "Incorrect advice. A Sapphire stylus is required for 78s and a Diamond stylus is required for 45s and LP's. A Diamond stylus will ruin a 78rpm record in very short order...why do you think I asked for both?"
SOURCE:
SOURCE: turntable plays too fast
I have seen this problem before. Lift the turntable off. It might be held down with a clip around the center pole. Under it you will see a wheel that contacts the turn table and the center shaft of the motor. The motor shaft has 3 0r 4 elevations with different diameters. When you change the speed the wheel will move up and down to different diameter levels on the motor shaft. It must be free to move. It might need some oil at the moving parts as I suspect it is not moving properly.
Hope this helps.
Posted on May 08, 2008
  • 69 Answers
SOURCE: Needs a needle
try this company?
mailto:info@needledoctor.com
Posted on Oct 07, 2009
SOURCE: Model DD1018, wont record, wont play back, tries
I just paid 30 dollaes to have a teck say that the laser was no good! they said a new laser would cost 250!!!! ya right! hope this helped u.
Posted on Dec 24, 2009
SOURCE: I have a Magnavox Micromatic stero console and
Record Town in Fort Worth has them. They are at 3025 S University Dr 817-926-1331. He has a couple on order for me now. His name is Sumpter. They have been in business there since 1949.
Posted on Apr 07, 2010
  • 63 Answers
SOURCE: how do i connect technics turntable model SL-QD33
Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
Posted on Feb 26, 2011
Where can i get turntable belt for tevion usb turntable
Ebay has been a good source for audio system/turntable components
tevion turntable belt eBay
Jun 05, 2017 | Audio Players & Recorders
I have a JVC AL-A158 turntable, just got it from a thrift store for $13. Cosmetically, it's brand new. No scratches, no scuffs, no nothing it's even still got the plastic on the 45 record adjustment, and I...
2 things, make sure the back arm weight is adjusted correctly,, allowing enough pressure to be placed on the record, if that doesn't help, you have a chip in the needle thats not visible to the naked eye,
Apr 30, 2011 | Audio Players & Recorders
WHAT IS THE STYLUS NEEDLE MODEL # FOR A RCA SS4000 RECORD PLAYER
Your source for all your antique radio, record player, turntable and phonograph needs!
Record Player Needles
Welcome to our record player needles and turntable stylus page! We hope you find this page to be very friendly and useful in locating a replacement record player needle or stylus for your phonograph. Use the picture charts of the record needles, and the information request form to help you identify which record player needle or stylus you need.
When it comes to stocking needles, we carry and stock more than just the "top brands", "most often needed" or "most popular" like other places you'll find on the web. Our inventory is very extensive and broad. Ranging from sophisticated high end types to plain straight steel needles for antique crank or wind up models.
Aug 31, 2009 | RCA Audio Players & Recorders
My turntables needle slides to the end of the record without playing.
is the stylis touching record.
what turntables have you got?
Aug 09, 2009 | Audio Players & Recorders
Looking for a needle for a turntable
May 14, 2009 | RCA Lawton 841.662 Turntable
Need new needle casing and needle for record player part of this
I would suggest that you look at the MUSONIC web-site. They specialise in cartridges and styli and will answer any questions by e-mail.
Jan 10, 2009 | Audio Players & Recorders
Turntable arm slides across record, Am. D.J.-1500
See what type of cartridge is installed in the arm. Manufacturers use common cartridges in turntables, such as Stanton, Shure etc. Detach the head shell from the arm (it usually slips right off via a locking ring and four-pin mini plug) Look for the manufacturer and model number on the cartridge. No need to remove it from the head shell. On most modern cartridges, the stylus (as they are called, rather than the needle) simply slips off and on. No need to remove the entire cartridge (via screws) and re-align it. In fact, many DJs bring a set spare cartridges and styli on a gig, already mounted in head shells, and simply interchange them as needed. When you have the make and model of the cartridge, go to Radio Shack or use their website to order a new one...or  two. Or go to Google and enter "phono stylus" as your search term. You will find reasonably priced styli for nearly every cartridge imaginable. I operate 50 year-old turntables and am able to find replacement cartridges and styli on line. Ebay also has a number of listings, by make and model of the cartridge. When the new stylus arrives, observe how easily the old one comes out of the cartridge- usually pull and slide - and slide the new one in. Re-insert the head shell on the arm, tighten the locking ring, and you're good to spin!
Jan 06, 2009 | Audio Players & Recorders
Low Volume from right speaker of entertainment center - turntable only
Hi There thanks for your very good desctiption of the problem it really helps to have a lot of detail...
There are Mono and stereo types of stylis cartridges and it sounds like you have a mono equipped into a stereo amplifier..
If there are 4 small coloured wires visible under the stylis then
its a stereo stylis and should work, have a close look and maybe one of the small wires has dropped of the small pins on the back opf the stylis cartridge.
If there only two wires visible then its a mono cartridge and this is why you only have sound from one channel..
So answer is wires dropped of the stylis.
or
Wrong type of stylis cartridge.
or
if there are four wires and thay all look connected then perhaps the stylis is faulty and you need to replace it...
Cheers from YU BEUT
Feb 02, 2008 | Audio Players & Recorders
Needle drag
Hi, i know this sounds stupid but have u tried using a different record as the record your using may have a defect which wont allow it to play any further. I would also make sure that you weight the tonearm as much as possible but not to much that you wear ur needles out. Let me know how you get on. Gud luck!
Nov 18, 2007 | Technics SL-1200MK2 Turntable
 Grubhead
Grubhead
Marvin
Marvin
