Question about Juki Sewing Machines
My juki TL-2010 sewing machine. It has stopped sewing, just makes a sound and won't sew.
SOURCE:
dupina
  • 110 Answers
SOURCE: Sewing machine is Stop with a Beep Sound
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Posted on Dec 04, 2007
  • 43 Answers
SOURCE: skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
Posted on May 07, 2009
  • 8 Answers
SOURCE: buttonhole problem
When doing the button hole....after installing the button hole foot and lowering the foot....and adding the button so the automatic button hole size is determined...you lower the button hole lever it will touch the back of the button hole foot. this holds the button hole foot in the proper position...if this lever is not all the way down...the machine blips at you...check to see that it is down all the way...I hope this helps you..It truly does all that it advertises and is a great machine...BBill01
P.S. you can adjust width and length of the stich also...see instruction manual. pg 28-30
Posted on May 30, 2009
Zenqi
  • 208 Answers
SOURCE: Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
Posted on Jun 17, 2009
SOURCE: Juki DDL-5530 Sewing Machine Manual
go to www.juki.com.jp login industrial sewing machine and you can doenload manual for juki machine
Posted on Aug 20, 2009
Bobbin thread not picking up on Juki Tl-2010
Try a brand new needle.
If that doesn't help, the machine may be out of time. Take it for service.
Jun 28, 2017 | Juki Sewing Machines
Juki sewing machine keeps sewing after releasing foot pedal
Your machine could be out of time. When you turn on does it stop or stitch a couple switches. Belt could be worn out as well. How old is it? Thank you very much. Please leave some feedback or more information so I may help you.
Jul 10, 2016 | Juki TL-98Q
Can I adjust the timing on my Juki TL-2010Q myself? I need realy detailed directions!
Have you replaced your needle first. Sometimes simply a new needle will do the trick. That Juki being a straight stitch only machine make it simple. When the needle reaches its lowest point and then starts back up about an eight of an inch. The point of the hook should be slightly above the eye of the needle and be directly behind the needle shaft.
Feb 02, 2016 | Juki Sewing Machines
How do I thread a juki tl 98q sewing maching
Its on page 17 of the User manual which can be found at
http://www.manualslib.com/manual/522990/Juki-Tl-98q.html?page=17#manual
Feb 28, 2015 | Juki Sewing Machines
Juki TL-98Q power problems
it could be the motor has gone out
or the power cord has gone out
only a sewing machine repair shop can say for sure
Feb 24, 2012 | Juki TL-98Q
My Juki TL-98Q won't turn on. No hummm, nothing. I've checked all connections and they are fine. Cords are in good shape. It was running beautifully prior to this.
If the light is on but no noise at all when you press on the control it must be a break in the lead at the very least or the brushes on the motor at the worst
Sep 30, 2011 | Juki TL-98Q
Sewing Machines Logo
Top Juki Sewing Machines Experts
TCHNICAL SUPPORT FOR...
Tally Girl
Tally Girl
Wayne Buss
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
