SOURCE: 70,000 btu reddy heater, starts right
I hope you are burning K1 kerosene as opposed to off road diesel. Diesel stinks no matter what you do to the heater. A couple things that have happened to me are, fuel selection K1 is it, when storing for the end of the season old fuel can cause water from condensation to build in the tank. When water is in the tank you get ignition and it burns just not hot enough to burn the fuel completely, this causes the heavy odor. Old fuel will do the same it is as if the fuel thickens to an oily state and becomes heavier. It just does not burn hot enough to get rid of the odor. You can try increasing pump pressure this changes air fuel mixture and you may get rid of the odor somewhat.
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
