Connect red and white RCA connectors to right and left 'audio in' on tv and connect yellow RCA to 'video input' on tv. https://www.6ya.com/callphilipforhelp
SOURCE: older citizen tv, hook up dvd player?
Radio Shack will sell you a device that should convert your signal to a format this old set can use
SOURCE: New vizeo 32" LCD TV -- black and white?
check to make sure that both are tuned to the same chanell.
Lou Margolis
Allied Electronics
[email protected]
SOURCE: hooked up dvd player to tv but no picture
Select Source button from your tv remote keep in AV mode than cheked if you have conected with yellow/red/white rca wire
SOURCE: Just moved, hooked up DVD player to new TV. Sound
if you have a picture on the tv from normal channels and/or cable, then i would suspect the scart lead may have a bent pin at one end or both or is not inserted fully.
SOURCE: manual for phillips magnavox 19 inch smart tv series
As there is no Menu button on the front panel of the TV, you must have its remote control to select inputs.
