Washing Machines Logo
A
Albert Acayan Posted on Jun 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bosch WFK2401UC recently started hanging up showing trouble code "01". I cleaned the filters at the tap and machine ends; did not help. Suggestions?
Eric Taylor
Level 3:
Master:
  • Master 590 Answers
  • Posted on Sep 27, 2019
Eric Taylor
Master
Level 3:
Master:
Answers
590
Questions
6
Helped
206022
Points
1556
Go online to the manufactures select user manual eric992
4 Related Answers
A
Anonymous
  • Posted on Jan 18, 2008
SOURCE: fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Anonymous
  • 1894 Answers
  • Posted on Aug 21, 2008
SOURCE: Bosch model WFK2401UC
please do a hard reset by leaving the unit plugged off from wall power for one night.
Anonymous
  • 228 Answers
  • Posted on Oct 28, 2009
SOURCE: Neff W4380X is showing error code 01
error code 1 is usually not heating it will progress through rinse as heat is not called for, when moves to heat stage will stop at that point inexpensive part to replace.
Harrie
  • 6746 Answers
  • Posted on Feb 24, 2015
SOURCE: Bosch WAY32540AU showing LOW WATER PRESSURE but pressure and taps are fine. All filters are clean.
Not sure how you can measure the pressure in the machine, but I think you did. When you did and the pressure in the machine is good, the sensor must be defect. BUT. if you did not measure the pressure in the machine, you should check if nothing is wrong with the water filter on the beginning of the water hose (closest to the tap) and you should check the hose is not bent and nothing is on it, throttling the free water flow.
Bosch washer WFK2401UC does not work with hot water.
Any of these. It is just water in, water out and two power wires. Look for one the same shape. You may be able to swap the mounting bracket over, or just drill new holes in the case.
https://www.google.com/search?q=Hot+water+inlet+valve+00171295
Having said that, the part is here!
https://www.repairclinic.com/ProductDetail/989550
https://www.google.com/search?q=Bosch+washer+wfk2401uc+water+inlet+valve
Bosch Series 6 Tap error symbol lit but pump and drain hose are fine. What can it be?
That normally signifies a leak. Under the machine there is a plastic pan with a sensor in it. However Bosch have a different idea.
https://www.google.com/search?q=Bosch+Series+6+dishwasher+Tap+error+symbol
How to start a diagnosis test on Bosch dishwasher model SHE3ARF6UC/21 will not start because of E01 code
Error code E01 means that your Bosch dishwasher is experiencing trouble with the motor.
1helpful
Bosch Washer WFK2401UC/01 Does not spin. Replaced Power cir. Bd. Turned on started right up. completed cycle. Went to wash this morning Drum will not spin
Sometimes the brushes on the motor get worn and they cause motor to act intermittently. I changed my brushes and this corrected the problem of not washing or spinning.
We have a bosch exxcel 1200, when we press start no water fills and machine does not start programme,however display window is working and showing normal functions
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Will not start on some wash programs, such as 40 or 60 fast spin, but will work when 40 woolens program selected, and other delicate programs too.
Check that the hot water tap is on or if the valve filter is blocked. If both these are ok, it may need a new hot water valve.
Hope this helps.
Use link item 171295 on page 4
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WFK2401UC%2f01&ESHOPTYPE=S
2helpful
I get a check water tap error 2 to 4 times a load
I have this problem. This code is due to restriction of water flow. In my case, we have sand in our water, and I have installed a filter between the water line and the washer. When it gets clogged, the flow is restricted and the Check Water Tap message appears. Your washer has filters on the back of the washer itself that may be clogged and need cleaning (which is why I installed the water filter between the washer & water line to prevent it from getting into the washer filter). Your washer manual shows you how to check/clean them. Also, you may have low water pressure during summer months due to lawn watering in your area that could cause this lower water pressure.
1helpful
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
