Just bought ONN CD and FM radio, put batteries in and it won't work. Has code P70H In display
ONN CD player with FM radio Model OND19AAA11
  • Ian Berry
    Ian Berry Jun 10, 2019
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Top Expert:
  • 935 Answers
As it's new the only thing I can think of is you may have accidentally put the batteries in wrong. If not, take it back as its defective.
Posted on Jun 10, 2019
    New Friend:
  • 40 Answers
Need more info to help like brand type
6ya staff
SOURCE:
Anonymous
  • 148 Answers
SOURCE: cd player
First of all, you aren't going to like this solution because it's the truth. If you rate me poorly, it's because you don't understand the truth. The optical pickup is bad and needs to be replaced. Anything made by Xtreme sound is poorly built. Yes, you're lucky to have even gotten four months use out of it. I've seen some that only last for two months and they die. Fortunately, that's why you didn't pay that much for it. I would suggest getting a Pioneer in the future.
Posted on Jul 16, 2006
alex Martin
  • 71 Answers
SOURCE: Replaced radio with one from same model year. Displays Err 01.
this generally means the laser is either dirty or the cd player is shot, err 01 is a disc reading problem. Try cleaning lens with cleaning disc first if this does not help i would replace the unit with another. i would recommend replacing it with a cheap aftermarket stereo.
Posted on Nov 27, 2008
lpgrind69
  • 8 Answers
SOURCE: I bought a used 2003 Jetta for my daughter with
I have come to find out that in the 90's auto makers started installing factory amplifiers in their cars so they could use low wattage stereos in the dash. It's usually a blue wire off the stereo that runs the amp, maybe it couldve become disconnected? I also know that even if you put in an after market stereo, this wire must be hooked up or you'll get no sound from the speakers. hope this helps.
Posted on May 26, 2009
sodeep
Sudeep Chatterjee
  • 3267 Answers
SOURCE: CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Posted on Jun 28, 2009
gfschef
  • 200 Answers
SOURCE: resetting radio code
You need to be very careful Each failed attempt causes a long delay before you can enter it again. Follow the instructions exactly. You may need to use the car for a day or more before attempting it again if you failed too many times. The radio should say CODE not ERROR. Error means no code can be entered now. You must wait until the radio displays CODE.
Posted on Feb 07, 2010
Onn a13av502 manual
https://www.walmart.com/ip/ONN-AM-FM-Digital-Clock-Radio/45832210
Is this the same model? I haven't seen an instruction manual anywhere I searched.
Feb 16, 2018 | The Audio Players & Recorders
How do I change my cd clock radio to AM
probably doesnt have AM option. You have high quality CD sound and high quality FM sound, they don't let you have bad quality AM. Having said that it does.
LISTENING TO THE AM/FM RADIO 1.
Press the ALM OFF/SOURCE button to select the FM or AM mode.
2.
Press the
/MIN button or
/HR button step by step to tune to the desired radio stations.
3.
Press and hold the
/MIN button or
next radio station in the direction of the search. The search operation simply finds stations with
strong signals. Stations with weak reception can only be tuned in manually
THIS MANUAL IS FOR THE 201
Onn ONB14AV201 Product Manual Product Features View
Jul 09, 2017 | Audio Players & Recorders
ONN CD Player will not play a disk but will play FM
Take it back to the store or call for warranty service
Jun 08, 2015 | Televison & Video
The remote for my radio/cd player won't work any longAny suggestions? The model is: jWIN JXCD3250 Classic Style CD/AM/FM
Remove the batteries, clean the battery terminals with rubbing alcohol and Q-Tips and replace the batteries with new ones, if no! I would suggest you have someone look at it, usually find bad solder connections that need touch up.
Feb 13, 2012 | Jwin JXCD3250 Classic Style CD/AM/FM...
I was attempting to install a new stereo in my 2000 taurus. it requires to an adapter to put the new stereo in. i got the new adapter and stereo in *kinda* but decided i didnt really know what i was...
check your fuses first. You may have blown one.
Visual Inspection Chart Mechanical Electrical
  • Integrated control panel (ICP) physically damaged, misaligned, any control(s) inoperative
  • Digital audio compact disc player physically damaged, misaligned, any control(s) inoperative
  • Antenna or antenna cable physically damaged, misaligned connection(s)
  • Radio speakers, mounting/speaker cones physically damaged, misaligned
  • Radio ignition interference capacitors, radio frequency interference suppression bond misaligned (also check for cleanliness and metal-to-metal contact)
  • Battery junction box (BJB) fuses F127 (5A), F117 (20A), F127 (5A).
  • Central junction box (CJB) fuse F227 (10A) F211 (15A), F216 (15A), F226 (10A) (wagon only)
  1. If the fault is not visually evident, proceed to diagnose the integrated control panel (ICP) by entering the ICP Self-Diagnostic Mode.
NOTE: To enter the ICP Self-Diagnostic Mode, the ICP must be ON and in radio tuner mode (AM/FM).
  1. Enter the diagnostic mode by pressing and holding preset buttons 3 and 6 simultaneously. This will suspend all radio functions, and display SP.
  1. Preset Button 1 = Audio internal/external SELF TEST. The display will flash SELF while gathering the diagnostic trouble codes (DTCs), then stop flashing when complete. Press the TUNE UP button to display the DTCs if any exist. Record codes and refer to the following table:
ICP SELF-TEST CODES Code Description 0 No diagnostic trouble codes logged 1 No response from rear chassis unit (RCU) 2 No response from cassette player 3 - 4 No response from compact disc player 5 - 6 - 7 No response from remote climate control 8 - 9 Read Only Memory Verification failed
  1. Preset Button 2 = Displays the feature strap for code identification, refer to the following table.
Code Description 01 Base-Electronic Search Radio (ESR) with Manual Climate Control (MCC) 07 Electronic Search Radio with Cassette (ESC) with MCC 17 ESC with Electronic Automatic Temperature Control (EATC) 97 Not programmed default of ESC with EATC
  1. Preset Button 3 = ICP and RCU identification. This test identifies the software level of the ICP and RCU. The ICP is tested first, followed by the RCU. The display will have two sequences of three codes each. The first sequence is for the ICP, the second sequence is for the RCU. For code identification, refer to the following table:
Item Part Number Description 1 - Product variant code 2 - Tape model 3 - CDR
SOFTWARE IDENTIFICATION CODES Product Type Code Description Product Variant Code Description 21 ICP 07
08
09
10
11
12 EATC with AM/FM, cassette player and CD changer
EATC with AM/FM and cassette player
Manual A/C with AM/FM and cassette player
EATC with AM/FM cassette player and CD changer 31 RCU 01
02
03 Analog
Digital
Midline 71 Remote climate control 01 LH drive 52 Compact disc/disc jockey 01
02
03
04 Sony® 10 disc
Sony® 6 disc
Clarion® 6 disc
FMS 6 disc
Sep 13, 2011 | 2000 Ford Taurus
Nov 18, 2008 | 1997 Saturn SL
145 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
